C_Strike Posted July 21, 2014 Share Posted July 21, 2014 Really starting to lose my love for my supra with all its problems at the moment:'( Would love to find out why for the last two days my engine is trying/ managing to cut out mid drive. The engine cut out completely (electrics where left running) and stranded me on a busy roundabout so I put it in park, turned the ignition fully off and tried to restart it and nothing. It only started again after about a two minutes of being left alone. The engine runs fine whilst its running but it sounds like its trying to choke itself. Il get to 2k revs in D and itl suddenly drop completely, a second later it pops back up to normal. I only got home by keeping it in 2 and keeping high revs for the mile home. What can I check? Clean? Do? Any help will be appreciated. Quote Link to comment Share on other sites More sharing options...
hiten55 Posted July 21, 2014 Share Posted July 21, 2014 not sure if its relevent, or even related but when I first got mine it used to stall randomly on pull off. Like it didnt know what to do so just shut itself down. I took it to Toyota, useless, then someone on here suggested cleaning or changing the gearbox sensor. Pulled it out, gave it a clean and hey presto problem fixed.... worth a shot..... Quote Link to comment Share on other sites More sharing options...
C_Strike Posted July 21, 2014 Author Share Posted July 21, 2014 Will try to check that. Is it easy to access? Any other suggestions? Quote Link to comment Share on other sites More sharing options...
C_Strike Posted July 21, 2014 Author Share Posted July 21, 2014 If it helps diagnosing, when it dies I cannot light the 'manu' button on the gearshifter. Seems like I can only restart the engine when the light illuminates again Quote Link to comment Share on other sites More sharing options...
ScottC Posted July 21, 2014 Share Posted July 21, 2014 Have you checked for fault codes? Quote Link to comment Share on other sites More sharing options...
C_Strike Posted July 21, 2014 Author Share Posted July 21, 2014 Was just trying but it seems we have no power to the light panel with the engine light...which doesnt help lol Quote Link to comment Share on other sites More sharing options...
purplewitch Posted July 22, 2014 Share Posted July 22, 2014 Gearbox sensor help worked for me too - mine used to just die on roundabouts when you're off the accelerator as you start to go round, hasn't done it at all since I got that sensor cleaned Quote Link to comment Share on other sites More sharing options...
C_Strike Posted July 22, 2014 Author Share Posted July 22, 2014 Whrre do I locate the sensor? Cheers Quote Link to comment Share on other sites More sharing options...
David P Posted July 22, 2014 Share Posted July 22, 2014 I'm not sure what a "gearbox sensor" is? yet I'd be suspicious of the speed sensor (location - rear of transmission) or throttle position sensor (location - throttle body). Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted July 26, 2014 Share Posted July 26, 2014 Sounds like a faulty starter relay to me, I've had this problem too! Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted July 26, 2014 Share Posted July 26, 2014 I'm sure I've read that aftermarket BOV can cause the auto to stall.... Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted July 26, 2014 Share Posted July 26, 2014 Why would the bov make it stall? think it through logically FFS Quote Link to comment Share on other sites More sharing options...
Ric Posted July 26, 2014 Share Posted July 26, 2014 Why would the bov make it stall? think it through logically FFS Why would a starter relay? once it's running... Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted July 26, 2014 Share Posted July 26, 2014 The starter relay does effect the engine stalling actually smart arse, I've had it happen on mine! As soon as you change it out of N it cuts the car out and the engine itself sounds like it has dropped a cylinder. My suggestion was from experience, not from internet bullshit! Quote Link to comment Share on other sites More sharing options...
Ric Posted July 26, 2014 Share Posted July 26, 2014 calm your warrior fingers pal i was just asking a question. Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted July 26, 2014 Share Posted July 26, 2014 Not a keyboard warrior mate, just trying to give good advice to find a solution! Quote Link to comment Share on other sites More sharing options...
jamesmark Posted July 26, 2014 Share Posted July 26, 2014 Why would a starter relay? once it's running... Valid question. The starter relay does effect the engine stalling actually smart arse, I've had it happen on mine! As soon as you change it out of N it cuts the car out and the engine itself sounds like it has dropped a cylinder. My suggestion was from experience, not from internet bullshit! Very poor response to an obvious question. Hopefully you're not as much of a smart arse yourself when people ask you something. This is a community after all. Anyway my curry is burning. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 26, 2014 Share Posted July 26, 2014 Does the check engine warning light come on reliably, every time you turn on the ignition, but without attempting to crank the engine? Do you have a multimeter and know how to use it? Quote Link to comment Share on other sites More sharing options...
np89 Posted July 26, 2014 Share Posted July 26, 2014 Why would the bov make it stall? think it through logically FFS Also a BOV will cause the auto to stall if its MAF as in UK and VVTI.......... do you need me to explain the logic or just call you a taxi?....... Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted July 26, 2014 Share Posted July 26, 2014 Why would the bov make it stall? think it through logically FFS Give your head a shake man! Have a read FFS...... Been loads of problems with BOV stalling autos. Did it with mine a few times so it's from experience. Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted July 26, 2014 Share Posted July 26, 2014 Also a BOV will cause the auto to stall if its MAF as in UK and VVTI.......... do you need me to explain the logic or just call you a taxi?....... Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted July 26, 2014 Share Posted July 26, 2014 I'm pretty sure I know what it is and tomorrow, hopefully we will have fixed it! One thing I do know for definite, is it won't be the BOV. Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted July 26, 2014 Share Posted July 26, 2014 I'm pretty sure I know what it is and tomorrow, hopefully we will have fixed it! One thing I do know for definite, is it won't be the BOV. Fair enough, nee need to get your nickers in a twist! Quote Link to comment Share on other sites More sharing options...
