NA-T misfire on boost
Josh42
Hi guys,
Maybe a little specialist, but just need to vent and get some ideas from yourselves.
Car is running the Whifbitz NA-T kit
BorgWarner S360
Siemens DEKA 650cc injectors
Fuel pulsation damper bypass
GTE Headgasket
ECU Master EMU standalone-w/built in 4bar MAP sensor
Inovit wideband AFR sensor
I have replaced the HT leads, distributor cap and rotor arm all for new OEM items.
At around 4k RPM I'm getting an intermittent misfire that is really starting to hack me off.
I've checked ignition timing and it's set to bang on 10degrees, if we increase the coil dwell, the issue goes away and the car will happily boost to 1.3 bar without any signs of det.
Any ideas on something I should be looking at?
Edited by Josh42 (see edit history)
