Defi gauge question
Kendo11
Evening all.
Just started my car tonight after a few jobs over this week and let it run for 5/10 minutes.
The engine temperature defi gauge went up to 120' and started sounding an alarm, whereas the stock temperature gauge was reading normal.
The coolant hose connector where the sensor is did feel pretty hot, but surely if it was that hot I wouldn't be able to even touch it?
The stock gauges are absolutely crap if I remember correctly, they stay in the middle until like 180 degrees or something daft like that. Not even worth having really as at that temperature, whatever has caused the overheat has probably already done the damage
Surely the most reliable of all would be the stock gauge?
Thanks nic, although I may just totally remove the set up
