paulj1 Posted July 16, 2014 Share Posted July 16, 2014 How long does it take to remove a supra fuel tank cover and any one got instructions of how to do it please as going to attempt to swap my new one on at weekend. Cheers Paul Link to comment Share on other sites More sharing options...
natony Posted July 16, 2014 Share Posted July 16, 2014 Its only a 10 min job and you should be able to look at your new one for the location of the bolt holes, i think theres about 6 Link to comment Share on other sites More sharing options...
Scooter Posted July 16, 2014 Share Posted July 16, 2014 refitting can be fiddly, there is (at least) one bolt that's tucked up out the way. 10mm (I think) ratchet spanner essential! Isn't there also a plastic piece between it and the rear bumper to remove? Link to comment Share on other sites More sharing options...
natony Posted July 16, 2014 Share Posted July 16, 2014 Link to comment Share on other sites More sharing options...
Ric Posted July 16, 2014 Share Posted July 16, 2014 Does the rear bumper need to come off to remove this? Link to comment Share on other sites More sharing options...
Carbon_Bullet Posted July 16, 2014 Share Posted July 16, 2014 Does the rear bumper need to come off to remove this? Yes, we'll makes the job a lot easier, took my rear bumper off when I did mine Link to comment Share on other sites More sharing options...
Konrad Posted July 16, 2014 Share Posted July 16, 2014 Does the rear bumper need to come off to remove this? No, you just remove 4 plastic clips at the bottom and it will move out of the way enough for a ratchet to get there I just removed fuel tank from mine to replace fuel lines. Link to comment Share on other sites More sharing options...
paulj1 Posted July 16, 2014 Author Share Posted July 16, 2014 Brilliant cheers guys Link to comment Share on other sites More sharing options...
Marcus GTE Posted July 16, 2014 Share Posted July 16, 2014 Was going to ask for the same info. So thanks for asking. Going to refurb mine though. Feel like doing it soon due to the info here. Link to comment Share on other sites More sharing options...
Westy Posted July 16, 2014 Share Posted July 16, 2014 Takes minutes to get it off...no need to remove the rear bumper either. Link to comment Share on other sites More sharing options...
2soops Posted July 16, 2014 Share Posted July 16, 2014 Piece of cake, 4 plastic clips at the bottom of the bumper and 6, 10mm bolts on the guard. Should take about 10 mins if the bolts aren't seized. You'll be amazed how much crap gets stuck between the cover and tank so watch your eyes if laying under it when removing. Link to comment Share on other sites More sharing options...
paulj1 Posted July 28, 2014 Author Share Posted July 28, 2014 Cheers guys going to do this on Saturday are all the bolts the same size that hold it on as I've just removed one so I can get some new ones but it's fairly short the one I've removed from the bottom of the protecter Link to comment Share on other sites More sharing options...
Marcus GTE Posted July 28, 2014 Share Posted July 28, 2014 I think the bolts are all the same. 10mm. There are plastic screws too that hold the clips onto the rear bumper. Just remember it's only the 10mm bolts you remove. The beefier ones hold the actual fuel tank on. Don't ask how I know that Did mine a couple of days ago. Link to comment Share on other sites More sharing options...
Kev.O Posted July 28, 2014 Share Posted July 28, 2014 Fantastic job Marcus. Link to comment Share on other sites More sharing options...
Marcus GTE Posted July 28, 2014 Share Posted July 28, 2014 Fantastic job Marcus. Cheers Kev, took it back to bare metal on most of it and was easy with an angle grinder. Link to comment Share on other sites More sharing options...
Kev.O Posted July 28, 2014 Share Posted July 28, 2014 Well worth the effort. What paint did you use? Looks brand new. Link to comment Share on other sites More sharing options...
Marcus GTE Posted July 28, 2014 Share Posted July 28, 2014 Well worth the effort. What paint did you use? Looks brand new. 1 coat of anti rust zinc primer 1 coat of gray halfords primer 1 coat of saab black from halfords (had it for the daily driver anyway) Still to put a clear coat on it. Again from halfords. It's not perfect , still a few rough spots as I didn't have a lot of time and only 2 coats of primer on the inside but a lot better than before. Link to comment Share on other sites More sharing options...
paulj1 Posted July 29, 2014 Author Share Posted July 29, 2014 Looks good Marcus I got one from a member on here then had my friend who owns a body shop to strip it and spray it can't wait to get it put on as old one looks gross from behind Link to comment Share on other sites More sharing options...
Marcus GTE Posted July 29, 2014 Share Posted July 29, 2014 Looks good Marcus I got one from a member on here then had my friend who owns a body shop to strip it and spray it can't wait to get it put on as old one looks gross from behind Cheers Paul, not put it back on yet but it can't look any worse than it did. Been bugging me for ages. Hope your happy with yours. Link to comment Share on other sites More sharing options...
paulj1 Posted July 29, 2014 Author Share Posted July 29, 2014 I'm going to have to take a pic of old against new its bugged me for the last few years how rusty it was Link to comment Share on other sites More sharing options...
paulj1 Posted July 29, 2014 Author Share Posted July 29, 2014 Gone to take bolt out to get some new ones and the whole tank protector has disintegrated not good so off to do it on mates ramp make it easier Link to comment Share on other sites More sharing options...
