Fuel tank cover removal
paulj1
Does the rear bumper need to come off to remove this?
No, you just remove 4 plastic clips at the bottom and it will move out of the way enough for a ratchet to get there :) I just removed fuel tank from mine to replace fuel lines.
Piece of cake, 4 plastic clips at the bottom of the bumper and 6, 10mm bolts on the guard. Should take about 10 mins if the bolts aren't seized. You'll be amazed how much crap gets stuck between the cover and tank so watch your eyes if laying under it when removing.
  • 2 weeks later...
Cheers guys going to do this on Saturday are all the bolts the same size that hold it on as I've just removed one so I can get some new ones but it's fairly short the one I've removed from the bottom of the protecter
I think the bolts are all the same. 10mm. There are plastic screws too that hold the clips onto the rear bumper.
Just remember it's only the 10mm bolts you remove. The beefier ones hold the actual fuel tank on. Don't ask how I know that ;)
Did mine a couple of days ago.
Well worth the effort. What paint did you use? Looks brand new.
1 coat of anti rust zinc primer
1 coat of gray halfords primer
1 coat of saab black from halfords (had it for the daily driver anyway)
Still to put a clear coat on it. Again from halfords.
It's not perfect , still a few rough spots as I didn't have a lot of time and only 2 coats of primer on the inside but a lot better than before.
Looks good Marcus I got one from a member on here then had my friend who owns a body shop to strip it and spray it can't wait to get it put on as old one looks gross from behind
Cheers Paul, not put it back on yet but it can't look any worse than it did. Been bugging me for ages. Hope your happy with yours.
