non turbo acceleration issues :(
Guest Pricer69
Guest Pricer69
hey guys just wondering is anyone could help me out.
ever since ive had the car the acceleration has been abit sluggish, going down the motorway going 60 in 5th, put throttle down and it would take at least 10 seconds just to get to 70:(
i got a mk4 supra sz NA.. my mate has exactly the same car with same mods and his pulls much quicker than mine does, it just seems i only have decent acceleration in 1st and 2nd :/
my clutch pedal is really high and someone i know said it is the clutch on its way out but it isnt slipping, could it be that? i literally have no idea what it could be so im hoping one of you lot could help me out :)
cheers :)
Guest Pricer69
the revs dont go up quicker than the speedo. i floor it and the speedo picks up slowly.. like real slow :(
i was goin 60 in 3rd the other day floored ot and there was a 2-3 second delay before the revs picked up.. but they were picking up slowly lol i dont inderstand
you haven't mixed water with the fuel have you :)
on a serious note - how does the engine sound?
are all 6 cylinders firing
when was it last serviced
have you checked the plugs and cables?
do the basics and report back.
Guest Pricer69
not that i know of haha the engine sounds beautifull mate nice and quiet, no tapping, no knocking, done service a few months ago replaced spark plugs, engine oil, filter, fuel filter its running nice an sweet :) apart from the power issue. i think i may just have to bite the bullet and try replacing the clutch then see what thats like
k - in that case its a NA, get used to it :)
Guest Pricer69
only gonna be a NA untill next year :p
- - - Updated - - -
i do need to change them aswell as replace dif and gearbox oil
Guest Pricer69
That's definitely wrong, my na pulls much better than that sounds.
Give it a full service and refresh everything
yeah mate its not good :( lol
im sure its something simple :)
Funny I was going to ask pretty much the same question only mine is an N/A. At 90 leptons plus it really drags it's heels and once I found a private place to test the limiter it was a ridiculous job trying to get it above that. Mine seems to pull OK low down but like the OP when it starts to get above 60 the power appears to peter off. I am in two minds on wether to spend money on new leads, distributor etc or just leave them until the winter and get a TT transplant. Problem is I might end up leaving it another year though so if there is anything cheap and easy to look at would help.
Guest Pricer69
mines a N/A too bro, yeah im just gonna change the dizzy cap and rotor arm for now see what happens
Have you driven any other N/A's as a comparison? My first thought would be are the calipers or caliper sliders seized, and the brakes dragging? Feel the discs after a few miles on the motorway without touching the brakes and coasting to a stop.
That had crossed my mind as the power seems to be speed related not engine rev related I'm either chronically un-aerodynamic or something is sapping the power. I get a vibration from the back that manifests itself in and around the 90-95 area as well so I suspect a back caliper isn't playing ball. I am just putting together a new UK spec front end may end up having to go with the back end as well.
