Where to skim and balance flywheel?
msmile
Balancing a flywheel without the crank coming out of the engine means finding a spare crank or making a mandrel shaft. A used crank is usually a lot LOT less than a custom mandrel....
I am aware of that, but it will give me more headache to get the crank out or even buy a new one. I have heard of some balancing mashines which can balance any flywheel using the center bearing hole only.
