Guest MartinSupra Posted July 9, 2014 Share Posted July 9, 2014 (edited) Hi guys, I've bought a 1993 Supra NA and it's does everything great. It had a speedoconverter fitted and it was behind de speedo. and there was a wire to the odometer to count mph. I want it to display km/h again so I deleted the converter and joined the original wires back together. The speedometer and the odometer are showing and counting km again. But now the turn signals and the hazard lights won't work The 7.5 a fuse at the footwell is in good working order, I even replaced it to be sure. And the fuse in the enginebay for the hazard/Horn is also OK, the horn works. I can't hear the relay clicking when I try to turn the turnsignals or hazardlight on. All my other lights work as it should. Any idea's ? I can't see the connection with the speedo- and Odometer converter and the turn signals... Or maybe it's a coincidence that the relay broke at the same time ? Where is that relay located ? Edited July 9, 2014 by MartinSupra (see edit history) Quote Link to comment Share on other sites More sharing options...
Rummy Posted July 9, 2014 Share Posted July 9, 2014 Are you sure the connector to the hazard switch has been reconnected behind the top dash? Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 9, 2014 Share Posted July 9, 2014 Are you sure the connector to the hazard switch has been reconnected behind the top dash? This. Take the top of the dash off and look behind the hazard switch. Chances are you've forgotten to reconnect it. Quote Link to comment Share on other sites More sharing options...
Guest MartinSupra Posted July 9, 2014 Share Posted July 9, 2014 Yes both left and right connectors are reconnected and all the lights are working (seatbelt, door open,batterie,cat heater). except the bulb of the rear light failure has been removed because of faulty sensor There were 2 wires in hazard switch that are now back to original, the pink wire and the blue-red wire. Quote Link to comment Share on other sites More sharing options...
Guest MartinSupra Posted July 9, 2014 Share Posted July 9, 2014 And even so, if the hazard switch isn't connected, does that mean that the turn signals switch on the steeringwheel won't work either ? Quote Link to comment Share on other sites More sharing options...
Rummy Posted July 9, 2014 Share Posted July 9, 2014 And even so, if the hazard switch isn't connected, does that mean that the turn signals switch on the steeringwheel won't work either ? Yes Quote Link to comment Share on other sites More sharing options...
Guest MartinSupra Posted July 9, 2014 Share Posted July 9, 2014 oh wait a minute.... how many connectors are on the top dashboard piece ? 1 left and 1 right ? Quote Link to comment Share on other sites More sharing options...
Rummy Posted July 9, 2014 Share Posted July 9, 2014 2 left, 1 right Quote Link to comment Share on other sites More sharing options...
Guest MartinSupra Posted July 9, 2014 Share Posted July 9, 2014 oooooh, I only reconnected 1 left and 1 right......haha stupid old me Thank u guys, I'll check it tonight after work, it was late last night Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 9, 2014 Share Posted July 9, 2014 oh wait a minute.... how many connectors are on the top dashboard piece ? 1 left and 1 right ? 2 left, 1 right oooooh, I only reconnected 1 left and 1 right......haha stupid old me Thank u guys, I'll check it tonight after work, it was late last night Haha, was going to say the warning lights run off of a separate connector and there will be a single connection above that for the hazards. Quote Link to comment Share on other sites More sharing options...
Blut_VTEC Posted July 9, 2014 Share Posted July 9, 2014 Quote Link to comment Share on other sites More sharing options...
