Dr Moz Posted July 9, 2014 Share Posted July 9, 2014 Hi, just thought I'd introduce myself. I'm Moz, I'm from Walsall & I've recently bought a 1995 NA auto in white. So far it's an absolutely fantastic car. Although the idle is a little high. Gonna check the vacuum hoses today & possibly clean the iacv. Link to comment Share on other sites More sharing options...
The Raven Posted July 9, 2014 Share Posted July 9, 2014 Hi mate. When my N/A idle was to high i found a monkey had adjusted the throttle cable to tight and it was pulling open a bit. Link to comment Share on other sites More sharing options...
stevie_b Posted July 9, 2014 Share Posted July 9, 2014 Hi Moz, You didn't say if it was a warm or cold idle, but NAs idle quite high when cold (2000rpm ish, a bit higher than the TT's cold idle). Link to comment Share on other sites More sharing options...
Dr Moz Posted July 9, 2014 Author Share Posted July 9, 2014 Already checked the throttle cable, there's a fair amount of slack in it. Cold idle is about 1700rpm, warm idle moves between 1100 & 1400rpm. Which I think is a bit excessive. Link to comment Share on other sites More sharing options...
stevie_b Posted July 9, 2014 Share Posted July 9, 2014 Yep that is a bit excessive. Warm idle on mine is around 700-800rpm with no hunting. Link to comment Share on other sites More sharing options...
The Raven Posted July 9, 2014 Share Posted July 9, 2014 (edited) Is it an auto? TPS fault? http://www.mkivsupra.net/vbb/showthread.php?283866-How-to-reset-the-Throttle-Position-Sensor Edited July 9, 2014 by The Raven (see edit history) Link to comment Share on other sites More sharing options...
Dr Moz Posted July 9, 2014 Author Share Posted July 9, 2014 Yeah, it's an auto. I'll check the tps too. Link to comment Share on other sites More sharing options...
SPG Posted July 9, 2014 Share Posted July 9, 2014 Welcome Moz Link to comment Share on other sites More sharing options...
Richie_k83 Posted July 9, 2014 Share Posted July 9, 2014 Welcome aboard dude! Glad you got it Link to comment Share on other sites More sharing options...
Dr Moz Posted July 9, 2014 Author Share Posted July 9, 2014 Had a clean around under the bonnet. Checked the hoses & made sure there was no blockages, reset the ecu & she's happily idling at about 750rpm. Happy days! Link to comment Share on other sites More sharing options...
supra_ufo Posted July 9, 2014 Share Posted July 9, 2014 welcome mate Link to comment Share on other sites More sharing options...
