Al Massey Posted November 2, 2014 Share Posted November 2, 2014 How did you get the rear quarter windows out? It's looking really good, love the green Link to comment Share on other sites More sharing options...
Why T Posted November 2, 2014 Author Share Posted November 2, 2014 Al Massey said: How did you get the rear quarter windows out? It's looking really good, love the green These were already out mate however its just sealant so a heat gun with some outward preassure should get it loose. also there should be 2-3 screws holding it on. Thnks mate, the green is nice. cnt wait till there fitted with my SRD intake Link to comment Share on other sites More sharing options...
Pudsey Posted November 2, 2014 Share Posted November 2, 2014 Glad the nuts arrived safe and sound buddy. You need to get a side view with those lovely colours. Some great progress will look superb once finished Link to comment Share on other sites More sharing options...
Why T Posted November 3, 2014 Author Share Posted November 3, 2014 Pudsey said: Glad the nuts arrived safe and sound buddy. You need to get a side view with those lovely colours. Some great progress will look superb once finished Yea got here nice and quick mate thanks a lot. Thanks mate, hard going but getting there slowly. here is a different pic. Think I'm gonna keep these studs. Like them Link to comment Share on other sites More sharing options...
Why T Posted November 3, 2014 Author Share Posted November 3, 2014 So today did some more wiring in the form of the front loom with the Fuse box. Now I'm trying to have all the wires as hidden as I can. So placed them in line to have a look. The plastics that go near the lights had to be removed and i re tapped the wires to make it neat. Did the same on both sides. Zip tied in place for now till i can get some clips. The ABS relays are gonna be underneath the offside wing to keep them hidden. Now been playing with the Fuse box to figure out where i could put it. I know people have tried every which way possible but I still tried. I know that's a silly place but really couldn't fit it any where else. As i don't want it in the bay this came with the car when I got it. It has already been lengthened what looks like enough to go into the cab. So I will be cutting and rejoining it all. Question is I want to be able to disconnect them again so are bullet connectors or similar OK to use on this. Suggestions will be much appreciated. So before I do all that decided to carry on with the interior, So I sorted out the engine loom so everything goes through the same hole again to make it neater. Put it through the hole into the cab so its there and then I can continue with the dash. Once it was in, I connected what I can then placed the heater matrix unit in. I hope it still works as well as the fuse box as I know they have been sat for a few years. I'm guessing there is no way to tell until everything is complete? so tomorrow, steering column and bar then maybe the dash can all go in. Yay Link to comment Share on other sites More sharing options...
Why T Posted November 12, 2014 Author Share Posted November 12, 2014 Not much has been going on. My leave has not been used for what i wanted it to. However still had some stuff delivered form Whifbitz and Mr T. Rear roof Seal and braided clutch line from Whifbitz. Thank you Paul. Roof side seals, 1 Door window strip, (still waiting on the other) and a few plastic clips for screws and the dash clips. Also received this lot from Rob Mitchell, RM Polishing, Lower/thermostat housing pipe and engine mount housings. Very Nicely polished as usual. As well as this, he has just finished some more items as well as some painted. Well chuffed with them thanks Rob Fuel Filler Necks!! Clutch Master Cylinder, Partly polished, partly painted. Painted on the inside of the heat shield. Power steering pump, mount and N/A Res. Mount and Res Painted in Shiny black, Pump painted in silver style paint. And a cap nicely polished to make my set into a 3 And engine lift hooks painted in shiny black as well. That's all for now. Cannot wait for some more parts and more items for RM Polishing. Link to comment Share on other sites More sharing options...
Guest supra_jogge Posted December 2, 2014 Share Posted December 2, 2014 good work! but its not purple Link to comment Share on other sites More sharing options...
skippyboyo1 Posted December 3, 2014 Share Posted December 3, 2014 wow this is ALOT of work. Fair play Link to comment Share on other sites More sharing options...
gavin.starr Posted December 3, 2014 Share Posted December 3, 2014 If your going to cut your loom to re locate the fuse box somewhere in thcab using crimps. Space your crimps out otherwise you will end up with a clump of crimps in one area which may prove harder to hide, and i would also purchase a propper crimping tool and crimps. As the plastic coated crimps from the likes of halfords are just shite. Get some like these http://www.ebay.co.uk/itm/3mm-Brass-Bullet-F-Crimp-Terminals-and-Covers-400pcs-/271557135646?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f3a110d1e#ht_55wt_1181 http://www.ebay.co.uk/itm/RATCHET-CRIMPING-TOOL-FOR-NON-INSULATED-CRIMP-TERMINAL-CONNECTOR-BLUE-/190879714786?pt=UK_In_Car_Technology&hash=item2c71514de2#ht_344wt_1181 Im sure you know that lol but i just thought i would share. Good luck with the rest of you build Gav Link to comment Share on other sites More sharing options...
Why T Posted December 7, 2014 Author Share Posted December 7, 2014 supra_jogge said: good work! but its not purple I know mate. I love purple but this one looks amazing in white. skippyboyo1 said: wow this is ALOT of work. Fair play Thanks Skippy mate, It is a hell of alot but im loving it gavin.starr said: If your going to cut your loom to re locate the fuse box somewhere in thcab using crimps. Space your crimps out otherwise you will end up with a clump of crimps in one area which may prove harder to hide, and i would also purchase a propper crimping tool and crimps. As the plastic coated crimps from the likes of halfords are just $#@!e. Get some like these http://www.ebay.co.uk/itm/3mm-Brass-Bullet-F-Crimp-Terminals-and-Covers-400pcs-/271557135646?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f3a110d1e#ht_55wt_1181 http://www.ebay.co.uk/itm/RATCHET-CRIMPING-TOOL-FOR-NON-INSULATED-CRIMP-TERMINAL-CONNECTOR-BLUE-/190879714786?pt=UK_In_Car_Technology&hash=item2c71514de2#ht_344wt_1181 Im sure you know that lol but i just thought i would share. Good luck with the rest of you build Gav Thanks for that bud. Helps alot, got a friend who says he can solder well so gonna do that, if not then im all over this Link to comment Share on other sites More sharing options...
Why T Posted December 7, 2014 Author Share Posted December 7, 2014 So after a couple of weeks with parades, marches and bull**** with work I finally got some time working with the car. Got a fair bit done today with some help from my mates. First off continued to sound proof the car but I ran out of sheets so I need to buys some more but, its looking good. Worked on the brake caps as well. Cleaned them and took off the horrible silver that was on there. The green is a bit too green so not 100% about it but this is only temp till Dim Sum is back up and running and Im in the uk. One is fitted just got to get round to doing the others. What do you think? Fitted the clutch Master cylinder, very well polished again by Mr Rob Mitchell thanks, aswell as the Throttle cable and the Polished fuel filler necks. They look especially good. Thanks Rob Couple of other small bits where done as well but not really interesting. More soon Link to comment Share on other sites More sharing options...
mplavery Posted December 7, 2014 Share Posted December 7, 2014 Looking forward to seeing this finished Looking good so far ! Link to comment Share on other sites More sharing options...
Why T Posted December 13, 2014 Author Share Posted December 13, 2014 mplavery said: Looking forward to seeing this finished Looking good so far ! Thanks mate, I am too Little update, Got the steering colum in today, Fixed the new dash with Q Bond. Also stuck my fingers to it haha. Changed the dash Loom over with my old one as well. All brakes are now on the car with lines all connected. Was about to put the dash in but realized I have to take everything out again so I can push the extended fuse box wire through. Great All good fun though. Loving it Link to comment Share on other sites More sharing options...
Scoot Posted December 13, 2014 Share Posted December 13, 2014 Just caught up with this build. Love it! Can't wait to see the whole thing complete. Link to comment Share on other sites More sharing options...
r0cknr0lla Posted December 13, 2014 Share Posted December 13, 2014 Build looks wicked bud.. gonna be a seious machine once done. Glad you enjoying it and good work! Link to comment Share on other sites More sharing options...
Why T Posted December 14, 2014 Author Share Posted December 14, 2014 Scoot said: Just caught up with this build. Love it! Can't wait to see the whole thing complete. Same here mate, just cant come any sooner r0cknr0lla said: Build looks wicked bud.. gonna be a seious machine once done. Glad you enjoying it and good work! Thanks mate Link to comment Share on other sites More sharing options...
Luxluc Posted December 14, 2014 Share Posted December 14, 2014 Nice work so far. Link to comment Share on other sites More sharing options...
Why T Posted December 14, 2014 Author Share Posted December 14, 2014 Little update. Dash About to go in As Carefully as I can getting it close to fitted AND ITS IIIINNNNNN!!!!!!!!! AAAAHHHHH :nana: Finally I have a dash and its almost a perfect fit. Think this is the first time it has been fitted since the re-trim so. All the wiring is now connected however I cant figure out a couple of connectors but not sure they where ever connected to anything. A random Pic as well. Link to comment Share on other sites More sharing options...
Guest Nicholas Posted December 14, 2014 Share Posted December 14, 2014 Why don't you sandblast and paint/powdercoat the front crash bar while everythings out? it looks very rusty. Link to comment Share on other sites More sharing options...
Why T Posted December 14, 2014 Author Share Posted December 14, 2014 Nicholas said: Why don't you sandblast and paint/powdercoat the front crash bar while everythings out? it looks very rusty. I want to mate but Im in Germany in the middle of nowhere and don't know anyone who can do it. Gonna get it done next winter when Im back in the UK Link to comment Share on other sites More sharing options...
Guest Nicholas Posted December 14, 2014 Share Posted December 14, 2014 Why T said: I want to mate but Im in Germany in the middle of nowhere and don't know anyone who can do it. Gonna get it done next winter when Im back in the UK Ah got you, just a pita taking the dash out again, builds looking good Link to comment Share on other sites More sharing options...
Why T Posted December 14, 2014 Author Share Posted December 14, 2014 Nicholas said: Ah got you, just a pita taking the dash out again, builds looking good Now that i know how to take it all out im happy doing it so its not to bad. Thanks Buddy Link to comment Share on other sites More sharing options...
Why T Posted December 15, 2014 Author Share Posted December 15, 2014 Nice day today, Didnt get much time however got some stuff done. Carpet going in, makes a difference ones its in, starting to look like an interior now. Set the wires in place for my heated seats from the group buy. Just need to wire them in once I figure out what i can connect them to. Any ideas? Bit that connects to the seat. Switch to mount on the dash. I also tidied up the wires to the rear and placed the amp wires in position. Hopefully Ill get the rest of the interior in on Wednesday before i go on Xmas Leave. Link to comment Share on other sites More sharing options...
Why T Posted January 14, 2015 Author Share Posted January 14, 2015 Update, Got the rear headlining off Stu over leave and fitted it today, as well as on of the plastics over the rear quarter windows. Not done much as not got alot of time. Also got some items polished from Rob. Will get pics up as soon as. Link to comment Share on other sites More sharing options...
Why T Posted January 18, 2015 Author Share Posted January 18, 2015 Been a very productive day today. Managed to get quite a bit done on the interior. First off I did the rear aerotop seal. Pretty simple to do and looks pretty good. As I had no metal bits that go between the front seal and the A pillar I used the ones from the hard top and cut them down. they actually look really good. I then went on to fit the Front seal. Had to make sure that with every seal that they were pushed into the grooves correctly. From there I focused on the roof itself. First off I placed everything out on the roof. 2x Seals L+R, 2x Brackets L+R I then went on to fit the re-trimmed leather roof lining, Fairly simple. And then on to the seals on the side. So that's brand new seals all round. God i hope it doesn't leak but we will have to wait and see. And then a test fit of the roof to see what it looks like and how it lines up. I am well chuffed with it. Then on to the interior. Carried on with the quarter panels and the roof. Fits well and looks really good. Due to the roll cage the roof was modified to fit and works well. One pic is with out the extra bit and one with. I then put the roof on again to see how it looks. Awesome I might say. Carried on with the plastics left and right and the kick panels that holds the carpet to the side. Rear seats in. The rear back rest doesn't fold forward now, roll cage is in the way lol. Link to comment Share on other sites More sharing options...
