Rear brake light
Guest suprageek
Guest suprageek
Just noticed that when the brake pedal is pressed one of the rear brake lights dosnt light up, but the bulb is working with the lights on, I also have one of heckler's PCB for the rear fog connected to this light which also works fine when switched on, is it just a dodgy bulb or something else? Thanks Dave
Those bulbs are double filament as far as I know bud, it's possible that while it seems to be working, the tail light filament could be ok but the brake light filament could be gone. Have you tried swapping the bulbs over? Would at least rule it out or in.
