Exhaust gas control valves.
Kaan W
Has anybody here ran one of these before and does it benefit having one? My main concern is the noise of running a 4" hks ti exhaust in the evenings. Im not too bothered about day time driving around the country side but through built up areas at night which is why I looked into these as it saves keep pulling over to put in/out a bung in the back box.
Another concern is with high powered cars will the valve restrict too much gas flow even when open fully? Or even fail due to the heat and pressure?
Cheers
Guest Budz86
If you ran one it would need to be on a switch, which I'm not sure is possible. Think a bung would be the easiest solution for you. I'll be looking into one as I've had similar concerns
