T14PPA Posted July 8, 2014 Share Posted July 8, 2014 I had my car on the ramp a couple days ago to do some work and although my chassis plate has the code for a lsd when i moved one wheel forward the other went backwards. You cant turn both wheels forward. That means no lsd right? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 8, 2014 Share Posted July 8, 2014 No, not necessarily. In fact it suggests it does not have an LSD. Was it in neutral at the time? Quote Link to comment Share on other sites More sharing options...
bobapple Posted July 8, 2014 Share Posted July 8, 2014 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 8, 2014 Share Posted July 8, 2014 Oh dear, that is BAD!!! Quote Link to comment Share on other sites More sharing options...
bobapple Posted July 8, 2014 Share Posted July 8, 2014 Sorry couldn't resist . Quote Link to comment Share on other sites More sharing options...
T14PPA Posted July 8, 2014 Author Share Posted July 8, 2014 I think it was in neutral. So now i have to buy an lsd? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 8, 2014 Share Posted July 8, 2014 I would pull the cover off and have a look inside if you are unsure whether it may not match the transmission code number on the VIN plate. Or you can see with a decent endoscope if anyone you know has one, via the filler plug. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted July 8, 2014 Author Share Posted July 8, 2014 I will chris thanks again Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 8, 2014 Share Posted July 8, 2014 I always thought that the Supra torsen diff behaved like an open diff, IE the other wheel turns in the opposite direction? Quote Link to comment Share on other sites More sharing options...
st3ven1 Posted July 8, 2014 Share Posted July 8, 2014 Spin up the rears and see if you leave an "11"(LSD) or a "1"(no LSD) on the road your private driveway. Quote Link to comment Share on other sites More sharing options...
SPG Posted July 8, 2014 Share Posted July 8, 2014 Spin up the rears and see if you leave an "11"(LSD) or a "1"(no LSD) on the road your private driveway. so true Quote Link to comment Share on other sites More sharing options...
T14PPA Posted July 8, 2014 Author Share Posted July 8, 2014 Ive done that and both wheels spun. Thats why im confused Quote Link to comment Share on other sites More sharing options...
LOGIE Posted July 8, 2014 Share Posted July 8, 2014 Ive done that and both wheels spun. Thats why im confused BOTH WHEELS SPUN....so 2 black lines? (11) you have a LSD. But me being me id need to take the plate off the back just to be awkward. Quote Link to comment Share on other sites More sharing options...
MRX Posted July 8, 2014 Share Posted July 8, 2014 I'm not too up on LSD's and why their desired. I understand in principle what they do i.e not letting one wheel slip much more than the other. Do they make a huge difference for launch? or improve handling? Quote Link to comment Share on other sites More sharing options...
LOGIE Posted July 8, 2014 Share Posted July 8, 2014 Try reversing or drawing forward very slowly with your steering on full lock. (This is not good for the power steering pump though) you inner rear wheel will judder and skip if you have a LSD. Or so ive been lead to believe. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 8, 2014 Share Posted July 8, 2014 I'm not too up on LSD's and why their desired. I understand in principle what they do i.e not letting one wheel slip much more than the other. Do they make a huge difference for launch? or improve handling?There is a huge handling benefit to having an LSD. Quote Link to comment Share on other sites More sharing options...
MRX Posted July 8, 2014 Share Posted July 8, 2014 There is a huge handling benefit to having an LSD. If they're that much better, wonder why they didn't just chuck them on all supra's. Was it an added extra you had to pay for? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 8, 2014 Share Posted July 8, 2014 If they're that much better, wonder why they didn't just chuck them on all supra's. Was it an added extra you had to pay for? They came as standard on many cars but not all. It's about cost - an LSD is very expensive relative to an open diff. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted July 8, 2014 Share Posted July 8, 2014 As far as I'm aware due to the nature of the TorSen LSD's you can't tell simply by rotating the wheels. You would be best removing the rear cover to check. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 8, 2014 Share Posted July 8, 2014 A TorSen diff will behave like an open diff if you're just turning the wheels on axle stands, well, every one Ive seen does. If the VIN plate has A02B (for example) and you leave a number 11, ts pretty safe to say its an LSD. The way I test is turning out of a junction, an open diff will light up the inside wheel, a torsen will just scrabble a bit. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted July 8, 2014 Share Posted July 8, 2014 All this talk of lighting up the tyres is OK, but how do you do the test if you have an NA? Quote Link to comment Share on other sites More sharing options...
Josh42 Posted July 8, 2014 Share Posted July 8, 2014 Like that. Quote Link to comment Share on other sites More sharing options...
bobapple Posted July 8, 2014 Share Posted July 8, 2014 How many people have a brake line lock on their Supra ? Quote Link to comment Share on other sites More sharing options...
Pig Posted July 8, 2014 Share Posted July 8, 2014 How many people have a brake line lock on their Supra ? Not many that I am aware of. Quote Link to comment Share on other sites More sharing options...
