supra tt cast manifold
Guest popenfresh
Guest popenfresh
Anyone know is Godspeed Mf-012 manifold will fit my j spec 1994 tt not sure if UK spec manifold has same stud pattern thanks
All TT heads share the same exhaust manifold stud pattern.. I am a fan of cast manifolds if they are made of decent, preferably high nickel content material, but check the wastegate port size, position, and whether the bolt pattern for it is likely to effect a good seal. The best were those by Arnout, but he stopped producing them years ago.
