Guest jimmyrs Posted July 7, 2014 Share Posted July 7, 2014 hi everyone, have noticed that my exhaust is blowing slightly... its hard for me to explain where so ive used pictures instead does anyone know where i can get these two different gaskets sourced? Had no luck through google trying to find something to fit :/ red circle is the area containing the yellow circle, to which i need a gasket, and also a gasket for the blue one also, how hard a job is this? im assuming just up on ramps + couple of bolts job done? thanks guys! Link to comment Share on other sites More sharing options...
Scooter Posted July 7, 2014 Share Posted July 7, 2014 Unless I'm missing something the Red and yellow pics are of oil residue from a weeping distributor oil seal and nothing to do with an exhaust blow? The other actual exhaust joint looks non standard. Do you have a first cat in? If you take all your plastic air intake stuff off, just a few 10mm bolts and then take of the silver manifold heat shield (careful here as the bolts/studs can shear) you'll see the cast manifold to y pipe section joints. The Y pipe should have a cat section after the two pipes join bit you may just have all pipework (ie a decat pipe) Link to comment Share on other sites More sharing options...
trebor69 Posted July 7, 2014 Share Posted July 7, 2014 The item circled in the last pic is one of your 02 sensors, can't make out anything exhaust related in the other pics. Link to comment Share on other sites More sharing options...
Nic Posted July 7, 2014 Share Posted July 7, 2014 Link to comment Share on other sites More sharing options...
Guest jimmyrs Posted July 7, 2014 Share Posted July 7, 2014 hi, sorry am new to supras, and cars in general (mostly played with bikes), but i dont mean by the circle to have selected the sensor - the sensor is fine and its not leaking from there - but it is leaking from the gasket behind that sensor in the picture (below the sensor) which is the exhaust? i think one cat has been removed, so its just a de-cat pipe? ill have to strip it one evening and take a closer look. as for sourcing one of these gaskets and replacing it - how easy is it? also, the distributor oil seal - where could i source one of these and again is it easy to change? Nic that website looks like what im looking for.. where can i find that? or is it just a pdf of parts? :/ Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 8, 2014 Share Posted July 8, 2014 I keep the disi shaft oil seals, e-mail me (do not PM) if interested. Depending on where you find the exhaust blow, I may be able to help with gaskets for there, too. Link to comment Share on other sites More sharing options...
TT Paul Posted July 8, 2014 Share Posted July 8, 2014 wkb toyota waterlooville are local.. Link to comment Share on other sites More sharing options...
Guest jimmyrs Posted July 13, 2014 Share Posted July 13, 2014 didnt think about a toyota dealer... will try them in the future! however have found out that it isnt the gasket blowing - but a huge crack around 180 degrees of the 2 into 1 exhaust section where it bolts onto the exhaust oxygen sensor bit... anyone know the best way to get these off? 14mm spanner has only been able to undo 1 of the 4 bolts! seriously tight in there.. have soaked it in WD40 in a hope that tomorrow itll free up a tad.. will keep you updated! Link to comment Share on other sites More sharing options...
trebor69 Posted July 13, 2014 Share Posted July 13, 2014 Socket and many extension bars then you'll be able to access it from underneath Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 13, 2014 Share Posted July 13, 2014 I would just add use a *VERY HIGH QUALITY* single hex wobble socket from the likes of Snap On, Facom or Stahlwille. If you round the damned things off an expensive socket will look dirt cheap. I have found them best undone when things are stone cold. They still catch me out from time to time, usually when someone is waiting for their car to get back home in, rarely when it's here for a week... Link to comment Share on other sites More sharing options...
Guest jimmyrs Posted July 14, 2014 Share Posted July 14, 2014 so, heres the bad news and the bad news exhaust has cracked fully all the way around - looks like its been repaired previously too - and the cause: no fucking exhaust bracket to hold it up - meaning it was literally being held from its connection to the manifold and 1 hanger near the rear of the car... and to make things worse the sensor in the 2 into 1 pipework had well and truely rusted itself stuck, or been bodge welded i cant tell but either way ended up having to cut the sensor and will later be soldering, heat shrinking and wrapping it all back together.. anyone got any pictures of what the exhaust bracket is supposed to look like? as you can see from my pics this is all that remains.. thanks Link to comment Share on other sites More sharing options...
Nic Posted July 14, 2014 Share Posted July 14, 2014 You'll easily find a used 2JZGE first cat if you post up a wanted thread in the classifieds section, alternatively bin the cat and replace with a straight through decat pipe http://www.garagewhifbitz.co.uk/garage-whifbitz-981.html Link to comment Share on other sites More sharing options...
Guest jimmyrs Posted July 14, 2014 Share Posted July 14, 2014 what would i do with the sensor if i bought this? Link to comment Share on other sites More sharing options...
Nic Posted July 14, 2014 Share Posted July 14, 2014 what would i do with the sensor if i bought this? That is the cat temperature sensor, it brings up a warning on the dash if the cat collapses or is blocked, it has no effect on the performance of the car and can simply be removed. Link to comment Share on other sites More sharing options...
Guest jimmyrs Posted July 15, 2014 Share Posted July 15, 2014 just ordered that decat from whiffbitz how long do deliveries usually take from there? also - i had a look on there but could not find any exhaust brackets.. any idea where id source one? thanks! Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 15, 2014 Share Posted July 15, 2014 (edited) I have an excellent used N/A bracket for £10 plus postage. New they are about £30.E-mail me at the address in my sig if you are interested, thanks. Edited July 16, 2014 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
Guest jimmyrs Posted July 15, 2014 Share Posted July 15, 2014 email sent! Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 16, 2014 Share Posted July 16, 2014 Bracket sent Link to comment Share on other sites More sharing options...
Guest jimmyrs Posted July 19, 2014 Share Posted July 19, 2014 thanks chris that bracket arrived swiftly! painted it up and put it on however it would not line up with the exhaust at all so ended up having to only use one of the bracket holes so its still pulling it away from the frame and hopefully will prevent it cracking again! thanks Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 19, 2014 Share Posted July 19, 2014 Even with the original Toyota catalytic converters the bracket to bellhousing and converter to exhaust mainifold bolts needed to be left loose and a certain amount of brute force used to align things. With aftermarket de cat pipes things usually get worse. So long as it's supported, that's the main thing. Cracked N/A first cats were very common, I have welded loads up. Link to comment Share on other sites More sharing options...
Guest jimmyrs Posted July 20, 2014 Share Posted July 20, 2014 ah good to know its a common issue atleast - shame the previous owner didnt even bother trying to replace it upon re-fitting though - inevitable that it would crack again with no support! oh well! thanks for your help chris! Link to comment Share on other sites More sharing options...
