Binding front j-spec caliper
Scutch0
My front drivers j spec caliper is binding, I've taken the sliders out cleaned and re greased them, they are now moving freely, however it still seems to be binding?
Is it common for the pistons to seize?
Any cheap remedy for this too?
How do you know it's binding? Is the roadwheel hotter than usual after a drive? Usually if the sliders are moving freely, the brakes don't bind. It's possible that one or both pistons are a bit stuck in the "out" position, in which case either strip the caliper down and rebuild it, or change the caliper as bignum said. If it's just an occasional use car, I would strip and rebuild: if you fit a 2nd hand calioper, unless it's been recently refurbed you don't know how long that one will last.
After a short drive there was a terrible smell of brakes, drivers side was considerably hotter than the rest, jacked the car up and I am only able to get the wheel to move using some force.
I've had the sliders out, I did notice 2 things, 1) that one was missing an inner rubber (the one attached to the slider), and 2) how much of a pain they are to get the slider back in without damaging the rubber.
I've rebuilt caliper a before, so I'm not that daunted by doing it myself, so anyone know where to get a rebuild kit? As the car only does about 2-3000 miles a year.
I'm tempted to try and work the pistons in and out to free them off, as they're not leaking or anything.
- - - Updated - - -
Can anyone point me where to get a replacement caliper?
