dangerous brain Posted July 6, 2014 Share Posted July 6, 2014 Do all supra's come with remote central locking? Ours didn't come with a remote key. There is a box under the passenger seat that I think is a remote locking ECU that I doubt would be there if it was not featured. It has a co-ax cable going into it and I first thought it was related to the radio ariel but there is only an input and no output so unlikely to be an ariel amplifier. I have also just found a red plastic card under the drivers seat that says it is a code card with a number on it. it's also got meta system embossed on it. Can you get replacement fobs for the remote locking and use a code or get the fob coded? Link to comment Share on other sites More sharing options...
drift_bear Posted July 6, 2014 Share Posted July 6, 2014 The box under the seat will be the stock amp Link to comment Share on other sites More sharing options...
dangerous brain Posted July 6, 2014 Author Share Posted July 6, 2014 Stock what amp though? Surely not the ariel amp? It's only got one co-ax in and a whole bunch of other wires in a large white plug. Surely an ariel amp would only need a coax in and out and a power and earth line? Might explain why my radio doesn't work. Link to comment Share on other sites More sharing options...
LOGIE Posted July 8, 2014 Share Posted July 8, 2014 The box under the drivers seat is the central locking ecu. Box under passenger seat is amp I think Link to comment Share on other sites More sharing options...
dangerous brain Posted July 8, 2014 Author Share Posted July 8, 2014 I know in Volvo's and range rovers you can code a new key by the key in the ignition or door lock so many times this way and that. Is there any magic like this on a supra if I got a replacement key fob? Link to comment Share on other sites More sharing options...
LOGIE Posted July 8, 2014 Share Posted July 8, 2014 I know in Volvo's and range rovers you can code a new key by the key in the ignition or door lock so many times this way and that. Is there any magic like this on a supra if I got a replacement key fob? This also worked on my mk1 rav4 (turn the ignition to "on" then lock-unlock 7 times (using central locking button on drivers door)then hold lock and unlock together for a few secs on fob and this put your fob code into the central locking ECU and you could put a total on 3 different fobs into 1 ecu. If toyota were doing it to their cars then chances are supra will be the same. Link to comment Share on other sites More sharing options...
