Remote central locking?
dangerous brain
Do all supra's come with remote central locking?
Ours didn't come with a remote key. There is a box under the passenger seat that I think is a remote locking ECU that I doubt would be there if it was not featured. It has a co-ax cable going into it and I first thought it was related to the radio ariel but there is only an input and no output so unlikely to be an ariel amplifier.
I have also just found a red plastic card under the drivers seat that says it is a code card with a number on it. it's also got meta system embossed on it. Can you get replacement fobs for the remote locking and use a code or get the fob coded?
I know in Volvo's and range rovers you can code a new key by the key in the ignition or door lock so many times this way and that. Is there any magic like this on a supra if I got a replacement key fob?
This also worked on my mk1 rav4 (turn the ignition to "on" then lock-unlock 7 times (using central locking button on drivers door)then hold lock and unlock together for a few secs on fob and this put your fob code into the central locking ECU and you could put a total on 3 different fobs into 1 ecu. If toyota were doing it to their cars then chances are supra will be the same.
