urgent Help: rear brake disc dimensions?
Angry Acorn
apologies i completely messed up the thread title! urgent* and just need help with the disc dimensions :twak:
You can edit the first post, then go advanced and you can change the title yourself :)
Oh, and caliper* too ;)
haha thanks but i just posted that link on another thread earlier, I know the standard dimensions i'm just wondering if 5mm will make any difference or cause them not to fit.
21mm width discs won't fit.
Hi all,
replacing the rear discs on my supra, would discs with the dimensions of 323mm X 21mm fit? the 323mm is correct its the 21mm I'm worried about? the discs are for the 2pot rear calipers Jap spec.
Jap spec calipers are single piston, sliding calipers. UK spec are twin piston, fixed calipers.
:clap: that made me laugh thanks, chris ill reply to your email in the morning I just need to sort out a logistical issue with those pistons as I wont be around end of next week but need them, appreciate all the help would be a very lost puppy without it haha
