LOGIE Posted July 6, 2014 Share Posted July 6, 2014 I know the SRD ones look to be good quality for the money. Im just wondering what else anyone else is running? Setrab etc and what sizes yous went for? Did you use braided hoses due to where its located? Cheers for any input guys. Quote Link to comment Share on other sites More sharing options...
David P Posted July 6, 2014 Share Posted July 6, 2014 I run two, one is a Land Cruiser item located in the right wing with a 13 row Racimex in the left wing via a Mocal oil-stat, good quality oil hose works fine. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted July 6, 2014 Share Posted July 6, 2014 I run srd one along side standard in rad in opposite side to the intercooler in front of washer bottle with norm oil pipes Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted July 6, 2014 Share Posted July 6, 2014 I run the SRD one too, Mounted my one to the rear of my SRD intercooler. Stays lovely and cool there. Quote Link to comment Share on other sites More sharing options...
Hassan Posted July 6, 2014 Share Posted July 6, 2014 Im running one 235mm 30Row mocal cooler with rubber hoses. Infront off my SRD rad. No problems at all. Quote Link to comment Share on other sites More sharing options...
Guest suprageek Posted July 6, 2014 Share Posted July 6, 2014 Yea I run 2 also srd one behind the intercooler and one below the passenger headlight, like dave said good quality oil hose works a treat Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted July 6, 2014 Share Posted July 6, 2014 I use to have mine between rad and intercooler but oil would still get hot when giving it some,have a seperate oil temp gauge for gearbox Quote Link to comment Share on other sites More sharing options...
LOGIE Posted July 6, 2014 Author Share Posted July 6, 2014 Thanks for the input guys.Is running one cooler alone enough for bpu or should I run with stock cooler also? Quote Link to comment Share on other sites More sharing options...
Hassan Posted July 6, 2014 Share Posted July 6, 2014 I use to have mine between rad and intercooler but oil would still get hot when giving it some,have a seperate oil temp gauge for gearbox Well i might move it to the oem intercooler location then. Or might just add a fan. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted July 6, 2014 Share Posted July 6, 2014 Heat is what kills the auto box Quote Link to comment Share on other sites More sharing options...
baldy Posted July 6, 2014 Share Posted July 6, 2014 25 row mocal were side mount was with a fan fitted to a thermo switch in the trans sump, no probs with burnt atf Quote Link to comment Share on other sites More sharing options...
Shane Posted July 6, 2014 Share Posted July 6, 2014 I use 2, one of these that is pretty much the same style as the SRD by the looks of it and is fitted well: http://www.ebay.co.uk/itm/Auto-Transmission-cooler-Trans-cooler-universal-10-x15-7-8-254-x-403-x-19mm-/321142067561?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ac58f1169 I also use one of these, and they fit perfectly either in the void in front of the washer bottle, or if you have FMIC, where the original SMIC fits, could have almost been made to fit a supra: http://www.ebay.co.uk/itm/OIL-COOLER-FOR-BOAT-RALLY-CAR-MITSUBISHI-PAJERO-SHOGUN-2-8-2-5-v6-9-x11-/221201321261?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3380a04d2d I run 2 only because I was getting concerned about how much power breaking I was doing on the strip. But I ran just the Mitsi one for an age before I added the other one. As David says, a mocal bypass thermostat makes sense for daily use, especially in the winter months. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted July 7, 2014 Author Share Posted July 7, 2014 I use 2, one of these that is pretty much the same style as the SRD by the looks of it and is fitted well: http://www.ebay.co.uk/itm/Auto-Transmission-cooler-Trans-cooler-universal-10-x15-7-8-254-x-403-x-19mm-/321142067561?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ac58f1169 I also use one of these, and they fit perfectly either in the void in front of the washer bottle, or if you have FMIC, where the original SMIC fits, could have almost been made to fit a supra: http://www.ebay.co.uk/itm/OIL-COOLER-FOR-BOAT-RALLY-CAR-MITSUBISHI-PAJERO-SHOGUN-2-8-2-5-v6-9-x11-/221201321261?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3380a04d2d I run 2 only because I was getting concerned about how much power breaking I was doing on the strip. But I ran just the Mitsi one for an age before I added the other one. As David says, a mocal bypass thermostat makes sense for daily use, especially in the winter months. Ideal 1st one looks ideal shane. Thanks. Quote Link to comment Share on other sites More sharing options...
Supraleeturbo Posted July 8, 2014 Share Posted July 8, 2014 I have 2 Srd coolers on mine :-) Quote Link to comment Share on other sites More sharing options...
