nuttynutz Posted August 29, 2005 Share Posted August 29, 2005 hello, right, went to test drive a TT auto. yup quiet a difference to my NA manual. but couple things i like to know. 1) the auto is definately not as responsive as my manual. has a slight delay. is that right? is the manual TT like that? 2) flooring it, the car seems to cut power then come back again, abit like when i hit the delimiter at 110mph, but at 40mph approx. instead. but towards the end of the test drive, it didnt seem to do it. any reason? 3) how much for a front end repray, eg, bonnet, wings, bumper. (has quite alot of stone chips.) probably more to ask, but thats all for now. Quote Link to comment Share on other sites More sharing options...
koolance Posted August 29, 2005 Share Posted August 29, 2005 best thing to do is drive the auto tt with overdrive off,, then it only drops 1 gear instead of 2 and i would see feels much more responsive Quote Link to comment Share on other sites More sharing options...
terribleturner Posted August 29, 2005 Share Posted August 29, 2005 Ollie, has the car had anything done to the engine it mod wise?? To give you an idea i had my new bumper, skirts and spats sprayed and fitted for £350 (i think), GVN in Chiswick will charge more though. Quote Link to comment Share on other sites More sharing options...
nuttynutz Posted August 29, 2005 Author Share Posted August 29, 2005 isit, the overdrive off in the first place on D? i didnt use 1 or 2, just kept it in drive. Quote Link to comment Share on other sites More sharing options...
Stu_Fraser Posted August 29, 2005 Share Posted August 29, 2005 My auto TT definitely does not cut the power when you floor it, kicks down straight away and your off. Quote Link to comment Share on other sites More sharing options...
nuttynutz Posted August 29, 2005 Author Share Posted August 29, 2005 nope, the engine is comepletely standard. standard exhaust too james will contact you later about bodywork if need to. just needed idea of price. thanks for the rough price though. wanted to sit in your car at bovingdon to see what your car was like. but had to leave early. otherwise, could then feel the difference between bpu against standard performance Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted August 29, 2005 Share Posted August 29, 2005 Hesitancy could be down to plugs m8. Again I would expect an auto to still be responsive even though it doesnt have as many gears. Quote Link to comment Share on other sites More sharing options...
terribleturner Posted August 29, 2005 Share Posted August 29, 2005 Ollie, i have a week off starting Thursday morning, if you like we can meet up and i'll let you take my beast for a spin Quote Link to comment Share on other sites More sharing options...
China Man Posted August 29, 2005 Share Posted August 29, 2005 next time you test drive a auto TT press the manual button and select the gear you want to floor it with. China Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 29, 2005 Share Posted August 29, 2005 that car doesnt sound right Quote Link to comment Share on other sites More sharing options...
Jake Posted August 29, 2005 Share Posted August 29, 2005 1) the auto is definately not as responsive as my manual. has a slight delay. is that right? No, not right at all. is the manual TT like that? No, neither are auto TT Supras that are running right. 2) flooring it, the car seems to cut power then come back again, abit like when i hit the delimiter at 110mph, but at 40mph approx. instead. but towards the end of the test drive, it didnt seem to do it. any reason?Probably needs a good service including a set of plugs. What condition was the air filter in? Ignore all the above stuff about turning overdrive off and/or putting it in MANU. You shouldn't need to do any of that Quote Link to comment Share on other sites More sharing options...
Kopite Posted August 29, 2005 Share Posted August 29, 2005 what's your budget mate? i'd buy Stu's while he's being insane and still sellin it Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 29, 2005 Share Posted August 29, 2005 Ignore all the above stuff about turning overdrive off and/or putting it in MANU. You shouldn't need to do any of that Agree completely, it should feel like one big 'powerband', no jerks or hesitation at all. Quote Link to comment Share on other sites More sharing options...
Paul -C- Posted August 29, 2005 Share Posted August 29, 2005 2) flooring it, the car seems to cut power then come back again, abit like when i hit the delimiter at 110mph, but at 40mph approx. instead. but towards the end of the test drive, it didnt seem to do it. any reason? Was the traction control kicking in? The standard one cuts in very hard! Quote Link to comment Share on other sites More sharing options...
nuttynutz Posted August 29, 2005 Author Share Posted August 29, 2005 ahh traction control, that may be it, i think i saw on the right dial, some traction light flashing or something every now and then. the car sounds very healthy, not that im a machanic, but it seems pretty solid. i couldnt work out why the car would jerk when i floored it hard. not a comparison, but my vr6 auto sharan is really smooth. all the way to any gear any speed. james, will see you to that but doubtful, am very busy sorting out my brothers wedding. Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted August 30, 2005 Share Posted August 30, 2005 isit, the overdrive off in the first place on D? i didnt use 1 or 2, just kept it in drive. overdrive is on until you switch it off. doesn't sound right though, mine pulls really well, without hesitation. i've not driven a manual tt though so i cant compare Quote Link to comment Share on other sites More sharing options...
nuttynutz Posted August 30, 2005 Author Share Posted August 30, 2005 overdrive is on until you switch it off. doesn't sound right though, mine pulls really well, without hesitation. i've not driven a manual tt though so i cant compare dont get me wrong, the car pulls away fine. just split second slower response to my NA manual. the hesitation is after about 3 second? 40mph ish? the car loses power then picks up again. i do think its the traction control now as stated by paul c. guess i need to get familier with all these extra functions to get it right? being an NA manual, never got to play with these overdrive and traction stuff. Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted August 30, 2005 Share Posted August 30, 2005 did you try it with traction control off? "slip cont" sometimes when i boot mine the traction light flickers, but i never lose power Quote Link to comment Share on other sites More sharing options...
nuttynutz Posted August 30, 2005 Author Share Posted August 30, 2005 well this is the first TT i went to test, silly me, didnt test and know what buttons to press etc etc. will do next time if i test it again or a differnt TT. Quote Link to comment Share on other sites More sharing options...
JohnA Posted August 30, 2005 Share Posted August 30, 2005 Don't forget that autos have the torque converter. This takes away some of the 'immediate' response, it's not as crisp as a manual. It feels like it revs up but speed doesn't change, like a slipping clutch, right? Quote Link to comment Share on other sites More sharing options...
