kwalker705 Posted July 2, 2014 Share Posted July 2, 2014 Anyone any tips on how to get off the damned nut holding the pinion wheel/ input flange on the diff ?? Cant get an impact socket to fit down onto it properly at all. Is there a special tool for it ?? Link to comment Share on other sites More sharing options...
David P Posted July 2, 2014 Share Posted July 2, 2014 (edited) Pneumatic jobbie and socket will shift it. Tight for 7 lbft aren't they? Edited July 2, 2014 by David P (see edit history) Link to comment Share on other sites More sharing options...
Dazzi Posted July 2, 2014 Share Posted July 2, 2014 Is that the 36mm/1-7/16 nut ? I had to weld a socket onto a 1-7/16 with a thin wall as my 36mm impact socket was too wide. Once I did this I used a crow bar to hold the flange and a very long bar. Link to comment Share on other sites More sharing options...
Lee P Posted July 3, 2014 Share Posted July 3, 2014 Use a hub nut socket Link to comment Share on other sites More sharing options...
kwalker705 Posted July 3, 2014 Author Share Posted July 3, 2014 I had a 36mm socket on it.. but it was too shallow to get past the "pin" sticking out of the centre of the nut/pinion shaft. Guess ill just have to find an even deeper one. Link to comment Share on other sites More sharing options...
Dazzi Posted July 3, 2014 Share Posted July 3, 2014 If you struggle mate I can send you my modified socket as long as you send it back Link to comment Share on other sites More sharing options...
