Engine Oil & Filter replacement.
Andrew
What's the thickest Oil I can run on a Supra TT?
Wanted to do an oil change yesterday, but they were out of Valvoline 5W/50. At the moment I'm running 0W/30, which most agree is too thin.
Valvoline seems to be very hard to get hold of were I live, so was considering changing to another oil.
My other question is the filter replacement, do get to it from above or below the engine bay? Looks like I can get to it from above if I move some stuff out the way, but it still looks very tight.
The reason for running a thicker oil is in relation to my "smoking exhaust" thread.
last time i got some valvolene oil i bought it off justin on torque ic
just got back from toyota a bit ago
and orderd a new oil filter think it was about £7
bought a load of bolts n gaskets too
the power steering tip is good will have to remember that and save the pic in this thread for future use
ps its 3 bolts on power steering tank
Originally posted by suprarob
I found it imposible to get to the filter from underneath by just jacking the car up.
Sorry I disagree, try coming from behind ;) the passenger wheel, and a good oportunity to check sub frame bolts.
Some people have used Castrol Magnatec 10- 40.
Guest Martin F
If you are struggling to find Valvoline, check your local Ford dealership. When i was last in there i noticed they sold a lot of it.
Still no joy from the Valvoline supplier, think I'll switch to Castrol 10W - 40 as that's a thicker oil.
Should have ordered from TorqueIC but want to change the oil this Saturday.
Some good tips there, I especially like the plastic bag trick :)
