centre warning light after active spoiler removal
supradanturbo
I have disconnected the spoiler button and put a metal clip between 2 pins. The same is done on the connector which was connected to the spoiler engine. Without the clips to the pins the warning light comes on. Not sure if this is what people mean by "disconnecting the ecu" but if it is, I can take pictures of the pins that needs to be wired if you like?
3 times its been said on this thread alone, Disconnect the ECU, that's not Bridging Pins, Or Removing buttons.
There is a 8cm by 6cm box ECU behind the stereo, it needs disconnecting.
I might have wrongly figured that the 2 minute bridging job was the "standard" way of doing it and I imagined disconnecting an ECU would throw some fault codes, so I mentioned it. Anyways, I would think leaving the ECU and bridging the button connector would be appealing to some especially if you don't have a double-din stereo like myself.
