Guest Bborat Posted June 28, 2014 Share Posted June 28, 2014 (edited) Hi folks, I,m putting the standard tt exhaust on my car, and I'm a total loss as to where I can purchase the gaskets which I believe are donuts in this case (can you use normal gasket types? I've got loads of those) ,,, if I go on eBay I find what appear to be the correct ones but when I read the description the I,D sizes quoted are way out (ie 42mm, when what's needed are much larger) Also one of the exhaust hangers looks a little different to the ordinary that I presume I can use,, any pointers there?? If all else fails il,ll order from Toyota but am sure there will be someone out there with them available at half the price, Help please.... Edited June 28, 2014 by Bborat Added piece (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 28, 2014 Share Posted June 28, 2014 If you mean the copper / steel/asbestos O rings used between first cat and second cat, and second cat and the rest of the exhaust, I have these, either new or excellent used. A small smear of exhaust assembly compound should be used as the flange recesses are bound to be rusty on a used system. I have used pigs nose hangars too, maybe a new one, but used will be fine. Quote Link to comment Share on other sites More sharing options...
