Ben m Posted June 28, 2014 Share Posted June 28, 2014 Do all these boxes use the same prop spline ie if I have an r154 the w58 or v160 prop would physically fit into gearbox and work? Link to comment Share on other sites More sharing options...
Swampy442 Posted June 28, 2014 Share Posted June 28, 2014 The 6 speed is dfferent for sure, I think they are all different but Im not 100% sure. Link to comment Share on other sites More sharing options...
Ben m Posted June 28, 2014 Author Share Posted June 28, 2014 Ok fair thanks Link to comment Share on other sites More sharing options...
listy Posted June 28, 2014 Share Posted June 28, 2014 No. In a MKIV Supra: W58 = W58 prop R154 = front section of MKIII Supra prop, mated to the rear half of a W58 prop V16* = V16* prop Link to comment Share on other sites More sharing options...
Ben m Posted June 28, 2014 Author Share Posted June 28, 2014 Sweet thankyou Link to comment Share on other sites More sharing options...
Guest FullAttack Posted June 29, 2014 Share Posted June 29, 2014 All these boxes use different splines.. The mk3 supra prop isn't the only one that fits an R154.. I'd be here for an hour trying to remember all the vehicles they use the 154 spline in, there's loads.. The Mk3 supra use an old style UJ, this is considerably better/stronger than the new sort seen on Mk4 supra, the old ones can be rebuilt/replaced, the newer ones can not. The newer ones are more likely to fail than an older one, iv seen the aftermath of a rear uj failing.. Wasn't pretty.. Link to comment Share on other sites More sharing options...
mikefinan Posted June 29, 2014 Share Posted June 29, 2014 R154 will take chaser props, although mk3 is used it isnt gospel Link to comment Share on other sites More sharing options...
