R154 w58 v160
Ben m
Guest FullAttack
All these boxes use different splines.. The mk3 supra prop isn't the only one that fits an R154.. I'd be here for an hour trying to remember all the vehicles they use the 154 spline in, there's loads.. The Mk3 supra use an old style UJ, this is considerably better/stronger than the new sort seen on Mk4 supra, the old ones can be rebuilt/replaced, the newer ones can not. The newer ones are more likely to fail than an older one, iv seen the aftermath of a rear uj failing.. Wasn't pretty..
