Project: LHD US spec TRD3000 Big Twin HKS 6 speed
x2k.dk
Another update
http://x2k.dk/images/Supra%20TRD1000/20150719_115653.jpg
http://x2k.dk/images/Supra%20TRD1000/20150719_124341.jpg
i relocated the battery to the trunk, and pulled a cable from the fuse box down to the starter and then from the starter under the car and drilled it inside the car behind the rear seat. here im relocating a fuse box. from the fusebox goes the cable to the battery. its now located in the left side of the trunk. pics will come later.
http://x2k.dk/images/Supra%20TRD1000/20150719_133222.jpg
http://x2k.dk/images/Supra%20TRD1000/20150719_133846.jpg
New oil cooler. broke the old one. had to relocate it sinde it wouldnt fit the new bumper.
http://x2k.dk/images/Supra%20TRD1000/20150723_164452.jpg
http://x2k.dk/images/Supra%20TRD1000/20150723_172926.jpg
Radiator ready to go in with the new colored fan cover
http://x2k.dk/images/Supra%20TRD1000/20150723_164701.jpg
Some random pics
http://x2k.dk/images/Supra%20TRD1000/20150723_172908.jpg
http://x2k.dk/images/Supra%20TRD1000/20150723_172913.jpg
colored fan SH.
http://x2k.dk/images/Supra%20TRD1000/20150723_173827.jpg
all fits well
http://x2k.dk/images/Supra%20TRD1000/20150723_185052.jpg
Water hose installed with the pipe. with HPS Fittings. the same used on the IC pipes.
http://x2k.dk/images/Supra%20TRD1000/20150723_193055.jpg
http://x2k.dk/images/Supra%20TRD1000/20150723_193539.jpg
Interiour parts recolored and fitted.
http://x2k.dk/images/Supra%20TRD1000/20150723_201141.jpg
http://x2k.dk/images/Supra%20TRD1000/20150724_212748.jpg
TRD covers installed and blinkers
http://x2k.dk/images/Supra%20TRD1000/20150725_205714.jpg
Ready to start the car
http://x2k.dk/images/Supra%20TRD1000/20150801_133210.jpg
http://x2k.dk/images/Supra%20TRD1000/20150801_173627.jpg
Servo/ steering wheels oil refilled (modified to fit between the fuse box and ic pipe.
http://x2k.dk/images/Supra%20TRD1000/20150801_173634.jpg
covers fitted.
http://x2k.dk/images/Supra%20TRD1000/20150801_205806.jpg
http://x2k.dk/images/Supra%20TRD1000/20150801_205845.jpg
facelift parts with new loom
http://x2k.dk/images/Supra%20TRD1000/20150801_205853.jpg
Santa came early this year :) 11x19 x4 :)
http://x2k.dk/images/Supra%20TRD1000/20150802_232715.jpg
http://x2k.dk/images/Supra%20TRD1000/20150802_232723.jpg
And TADAAAAA :)
Finally out for a test ride..
http://x2k.dk/images/Supra%20TRD1000/20150805_1929367.jpg
http://x2k.dk/images/Supra%20TRD1000/20150805_192944.jpg
http://x2k.dk/images/Supra%20TRD1000/IMG-20150804-WA0001.jpg
Well the test ride didnt go as well as i hoped. Engine performed very good but the new radiator and fan cover didnt mix well. the cover hit the fan and broke in to 1000 pieces. and made a hole in the radiator :(
so had do drive home VERY slowly.
i also found out that the DIFF is leaking. i guess the stiff mountings were to hard for it. think im gonna go back to the stock bushings. Had some made for drag reasons in metal.
  • 2 weeks later...
Thanks for the kind words Guys.
ive been on holiday but now back at it again.
Here you see the problem that the fan caused.
http://x2k.dk/images/Supra%20TRD1000/20150805_192600.jpg
and my lovely clutch pedal that broke just before i drove the car into the garage :) Lucky me..
http://x2k.dk/images/Supra%20TRD1000/20150827_150800.jpg
http://x2k.dk/images/Supra%20TRD1000/20150827_150819.jpg
I installed a GPS tracking Alarm and removed all the pannels again.
http://x2k.dk/images/Supra%20TRD1000/20150804_182537.jpg
http://x2k.dk/images/Supra%20TRD1000/20150814_131739.jpg
http://x2k.dk/images/Supra%20TRD1000/20150814_131746.jpg
http://x2k.dk/images/Supra%20TRD1000/20150814_131755.jpg
http://x2k.dk/images/Supra%20TRD1000/20150814_131803.jpg
http://x2k.dk/images/Supra%20TRD1000/20150814_131816.jpg
The BAttery installed in the back in the "hole" that i build for it. fits perfect with the plastic cover on top.
http://x2k.dk/images/Supra%20TRD1000/20150814_150557.jpg
ANd offcourse the tools :)
http://x2k.dk/images/Supra%20TRD1000/20150814_150604.jpg
http://x2k.dk/images/Supra%20TRD1000/20150814_151616.jpg
Edited by x2k.dk (see edit history)
  • 2 weeks later...
just found out that the diff is leaking because of a very small crack you can see on top of the skrue.
i hope i can weld it. i gotta see. otherwise i have to get a new plate in the rear
http://x2k.dk/images/Supra%20TRD1000/11987100_1625638917721869_8785638809661854179_n.jpg
  • 1 month later...
