Jellybean Posted June 25, 2014 Share Posted June 25, 2014 What is the name of the black box on the strut tower behind the Fuse box in the engine bay , on after market ECU's it is normally replaced with a HKS DLI If you disconnect , car cranks but wont start Link to comment Share on other sites More sharing options...
Guest Budz86 Posted June 25, 2014 Share Posted June 25, 2014 Think that's the ignitor pack, so provides the signal for the plugs to spark Link to comment Share on other sites More sharing options...
Jellybean Posted June 25, 2014 Author Share Posted June 25, 2014 Think that's the ignitor pack, so provides the signal for the plugs to spark thanks , that rings a bell Link to comment Share on other sites More sharing options...
Wez Posted June 25, 2014 Share Posted June 25, 2014 on after market ECU's it is normally replaced with a HKS DLI The HKS DLI is only an amp and works alongside the stock ignitor, doesnt replace it Plus a HKS DLI is only required on ECUs that convert from direct fire to wasted spark like the original PnP AEMs, if you maintain direct fire ignition its just another box to go wrong so better off being ditched..... Link to comment Share on other sites More sharing options...
Jellybean Posted June 25, 2014 Author Share Posted June 25, 2014 The HKS DLI is only an amp and works alongside the stock ignitor, doesnt replace it Plus a HKS DLI is only required on ECUs that convert from direct fire to wasted spark like the original PnP AEMs, if you maintain direct fire ignition its just another box to go wrong so better off being ditched..... Sorry my bad thanks Wez! Link to comment Share on other sites More sharing options...
