theredone Posted June 24, 2014 Share Posted June 24, 2014 Anybody got any usefull info on fitting an emanage blue, wires that need splicing etc any diagrams about? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 24, 2014 Share Posted June 24, 2014 http://www.greddy.com/upload/file/e-manage_Blue_Install.pdf And there is an ECU pin-out on here if you do a search. Quote Link to comment Share on other sites More sharing options...
theredone Posted June 24, 2014 Author Share Posted June 24, 2014 Thanks, is the 2jz-ge wired in the same as the gte, as in wire locations on the ecu connectors? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 24, 2014 Share Posted June 24, 2014 Couldn't find the ECU pi out that used to be on here, but found this for you, http://www.jegs.com/InstallationInstructions/0/017/017-30-1100.pdf Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 24, 2014 Share Posted June 24, 2014 It takes some finding Ricky, I can never locate the bugger so here it is again: Some search terms for in the future: E-Manage wiring diagram spreadsheetEM Wiring.xls Quote Link to comment Share on other sites More sharing options...
theredone Posted June 24, 2014 Author Share Posted June 24, 2014 Sorry guys i dont think there any use as mine is a 2jzge and the diagrams show gte loom :/ Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 24, 2014 Share Posted June 24, 2014 It takes some finding Ricky, I can never locate the bugger so here it is again: Some search terms for in the future: E-Manage wiring diagram spreadsheet Sorry guys i dont think there any use as mine is a 2jzge and the diagrams show gte loom :/ Found it in the end Ian, and here is a link to the post with the GE pin outs. http://www.mkivsupra.net/vbb/showthread.php?35919-ECU-Pinouts&p=2726447&viewfull=1#post2726447 Quote Link to comment Share on other sites More sharing options...
theredone Posted June 25, 2014 Author Share Posted June 25, 2014 Thanks ricky, ill have a look at fitting it later then Quote Link to comment Share on other sites More sharing options...
