dangerous brain Posted June 21, 2014 Share Posted June 21, 2014 In went an MR2 steering wheel, Double DIN DVD player and smoked side indicators today lol Quote Link to comment Share on other sites More sharing options...
sean2kuk Posted June 21, 2014 Share Posted June 21, 2014 can you explain how you fitted this steering wheel please.....parts needed ect....mine has cruise control Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted June 21, 2014 Author Share Posted June 21, 2014 I took the old one off and put the new one on, simples no parts needed other than the steering wheel. Mine doesn't have cruise control so I don't really know how it would affect proceedings as I don't know if the cruise control is part of the steering wheel housing or separate from it. If the cruise control is integral to the steering wheel then maybe one of the rev 3 MR2's or similar year celica came with cruise control? Mine also doesn't have an airbag system. Dunno if it would be simple to retro fit the wiring and ECU/sensor to make use of the airbag? Quote Link to comment Share on other sites More sharing options...
sean2kuk Posted June 21, 2014 Share Posted June 21, 2014 i remember seeing a member on here did it and put up a thread with pictures of how he achieved it...... im not 100% but i think it was a member called littler on a black tt supra??? ive searched for it but as of yet no success Quote Link to comment Share on other sites More sharing options...
drew 007 Posted June 21, 2014 Share Posted June 21, 2014 Wasn't it a Yaris or a Celica wheel?? Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted June 21, 2014 Author Share Posted June 21, 2014 (edited) I'd imagine that a Celica would be more likely to have cruise control as standard than an MR2 would. Looking on Ebay at a celica it has the same steering wheel I just fitted and say it has cruise control so it would appear that the cruise control switch stuff is in the control column not with the steering wheel. Only way to really tell is by looking at your own car and seeing where the cruise control is. I do however also recollect seeing a thread about fitting a different Toyota steering wheel and having to trim something to keep the cruise option. Yup it can be done as suprasstore in the US retail the bad boys for $450 robbing gits! I see the stalk now and where it goes. From memory all you need to do is cut the plastic trim on the back of the steering wheel to accommodate it. Edited June 21, 2014 by dangerous brain (see edit history) Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted June 21, 2014 Author Share Posted June 21, 2014 (edited) The Lexus IS one has that stalk on it so they are out there so you can see in that picture that the stalk just secures to the steering wheel with a couple of screws. There is a hole in the plastic at the back for the stalk to come through. And if you look at this one you'll see that there are holes where your cruise control stalk should bolt up. Edited June 21, 2014 by dangerous brain (see edit history) Quote Link to comment Share on other sites More sharing options...
Littler Posted June 21, 2014 Share Posted June 21, 2014 i remember seeing a member on here did it and put up a thread with pictures of how he achieved it...... im not 100% but i think it was a member called littler on a black tt supra??? ive searched for it but as of yet no success You called Here's my thread that your looking for http://www.mkivsupra.net/vbb/showthread.php?271923-My-New-Steering-Wheel-With-A-Unique-Mod-FINALLY-FITTED-29-6 Quote Link to comment Share on other sites More sharing options...
sean2kuk Posted June 21, 2014 Share Posted June 21, 2014 brilliant...but im still confused.....did u just attach the cruise control stork onto an existing hole on wheel or did u modify it to fit......would i need a boss kit or connectors? Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted June 21, 2014 Author Share Posted June 21, 2014 By the looks of it just cut the hole in the plastic and the rest is plug and play dude. Sort of what I intimated with the pictures above. Didn't know the resistors were different so buying a steering wheel with a stalk on it already from another car means the stalk from that car wont work. Also picking up on an angular issue resolved by using a facelift model cruise stalk? All semantics really as I don't have cruise control and even if I did I wouldn't use it as any car I've ever had with it I didn't like it due in no small part to the fact that people don't drive at a constant speed ever! Quote Link to comment Share on other sites More sharing options...
