Mgrene Posted June 20, 2014 Share Posted June 20, 2014 Before you start chasing me. Yes I have used the search button but didn't find any useful answer. I have also tried to search through google without luck. I am often wondering what the right pressure is. Right now I am running 36psi in all four wheels BUT is this correct, epecially taking into consideration that I am running very low profile. Front: Falken 245/35 19" Rear: Continental 315/25 19" Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 21, 2014 Share Posted June 21, 2014 There will be no defined pressures, once you start fitting funny sized wheels and tyres it becomes experimental. Whatever pressures you run it'll handle like @#*& though, IMHO. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted June 21, 2014 Share Posted June 21, 2014 On such a low profile, I would not go below 35.5 psi to avoid damaging the rim on bad roads. Quote Link to comment Share on other sites More sharing options...
Chris88 Posted June 21, 2014 Share Posted June 21, 2014 I've just sold my 911 over in China and it had 315/25 rears. Pressure on them (using Nitrogen because of the 35C heat) was 2.9 bar / 42 psi. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted June 21, 2014 Share Posted June 21, 2014 Normally I see posted around 36 + or - 1. Quote Link to comment Share on other sites More sharing options...
