jdmjak Posted June 20, 2014 Share Posted June 20, 2014 hey guys just need a little info on parts that are needed for a na-t conversion. this is the list of parts i have and parts i will be buying over the next few weeks: xspower t61 turbo kit Greddy emanagae ecu and map sensor 550cc injectors 225lph fuel pump clutch and lightweight flywheel oil filter sandwich plate 4 runner dizzy cap 7psi wastegate spring aem wideband afr boost gauge intercooler piping im just looking to do pretty much a plug and play conversion for around 350-400hp and from what i have read the parts above is pretty much all i need but i would just like to ask the guys that have had experience and already done the conversions to see if this is actually everything.any help here would be much appreciated. Quote Link to comment Share on other sites More sharing options...
listy Posted June 20, 2014 Share Posted June 20, 2014 You could just buy an NA-T kit from Whifbitz Quote Link to comment Share on other sites More sharing options...
J_Supra_07 Posted June 20, 2014 Share Posted June 20, 2014 Don't need injectors or pump an less your fitting a tt gasket Quote Link to comment Share on other sites More sharing options...
J_Supra_07 Posted June 20, 2014 Share Posted June 20, 2014 Emanage will use the stock map sensor but need the injector harness Quote Link to comment Share on other sites More sharing options...
jdmjak Posted June 20, 2014 Author Share Posted June 20, 2014 (edited) will the stock fuel system be able to manage 400hp? i have heard you need to upgrade the fuel system to achieve this. also heard that its probably best to get a top line wastegate such as a precision turbo p46 wastegate so i will be ordering one of those also Edited June 20, 2014 by jdmjak (see edit history) Quote Link to comment Share on other sites More sharing options...
Dazzi Posted June 21, 2014 Share Posted June 21, 2014 400hp or near enough can be achieved if you have an upgraded fuel pump, FPR and run decent fuel to stop detonation. I think Noz is running 417hp at 10psi? with stock head gasket etc. Quote Link to comment Share on other sites More sharing options...
jdmjak Posted June 21, 2014 Author Share Posted June 21, 2014 cheers dazziiii!! Quote Link to comment Share on other sites More sharing options...
Bayden_uk Posted June 22, 2014 Share Posted June 22, 2014 keep me updated on how you get on and what rout you take. looking at doing this my self or just ordering a TT VVTI Quote Link to comment Share on other sites More sharing options...
