supra parts difference uk n import
mik3ysupra
Hi all im new here just purchased my first supra and i need to do the following
change the exhaust as my back box is small and sounds abit gay i want it to sound more meaty and at least pop and bang and mean it rather than a tin can fart pop
but my issue is mine an na so where can i buy an exhaust for it as all the ones on ebay say for tt model or do they all fit na and tt
also i need to change disc and pads yet again iv heard uk brakes are bigger and better than import brakes , i have import brakes on mine so where is best place to purchase my disc and pads as on ebay and site just says fited supra tt model .
i may just be stupid and reading it all wrong but i am confused to shit :(
many thanks
As far as im aware all exhausts will fit, if you want your N/A to be loud then buy a 3" exhaust and also buy double decats.
With regards to the brakes everyone will highly recommend UK brakes all round, they're a massive improvement over J-spec brakes. Have a look on Garage Whifbitz at their exhausts and brakes. You should get a discount on genuine toyota parts if you buy through them.
thanks for the reply , i take it you mean replacing the whole brake caliper set up am i correct , and thank i didnt know the exhausts fitted both i belive the car is already decated also but last owner had silencer fitted
The exhaust on the NA and TT from the 1st cat backwards are identical, a catback exhaust designed for a TT will fit an NA however it will be a lot louder. There are exhausts available that are specifically designed for the NA, these usually use slightly narrower piping (2.5" rather than 3") and have an extra silencer on the mid pipe.
The J-spec NA and TT Supras were factory fitted with 2 brake options, either the smaller 2pot front/1pot rear brakes or the larger 4pot front/2pot rears (all UK Supras were fitted with the larger brakes). More details here: http://www.mkivsupra.net/vbb/showthread.php?249089-Supra-Brake-setups
