shaz2010 Posted June 17, 2014 Share Posted June 17, 2014 (edited) Is this normal ? http://s1063.photobucket.com/user/Supra_shaz/media/Mobile%20Uploads/trimE8CD2F96-81CF-4431-904C-B78CC97DF596.mp4.html As am getting a clonk when either reversing while turning or braking ! I've just torqued up the sub frame bolts need to do the deep reach ones later when a get a socket for it. Any ideas what it could be if not the hub noise or sub frame? Edited June 17, 2014 by shaz2010 (see edit history) Quote Link to comment Share on other sites More sharing options...
2soops Posted June 17, 2014 Share Posted June 17, 2014 Yes the video is normal movement. There's no retaining bolt/screw on Supra disks so it will do that. When the wheel is torqued on then that should stop it as it clamps the disk to the hub too. Your clunking sound is probably coming from somewhere else, ball joints, loose subframe or bushes most likely Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted June 17, 2014 Author Share Posted June 17, 2014 Yes a stupidly thought that was it haha but when a thought about it after a posted I reliaed the wheel would stop it from moving. Emm so next will be to tighten the other sub frame bolts, then move onto what you have mentioned. Quote Link to comment Share on other sites More sharing options...
