barneybrendan Posted June 16, 2014 Share Posted June 16, 2014 I new the car had overheated previously so fitted thermostat and its still overheating. I checked the. thermostat and that seemed to be working fine. Bottom hose cold top hose boiling. Temperature then goes up into the red.ive flushed the system out as water was just brown rusty, no coolant in there at all.ive had rad cap off and it overheats, rad cap on it overheats. Quote Link to comment Share on other sites More sharing options...
L18msy Posted June 16, 2014 Share Posted June 16, 2014 A blocked radiator perhaps? Waterpump? I have heard of the rad cap breaking and falling in before? I did the coolant when I first got the car years ago but I am guessing if it been overheating it has lost the coolant along the way? Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 16, 2014 Author Share Posted June 16, 2014 Rad must be ok as I had bottom pipe off as I was flushing it through and water was coming out great plus it was coming out of thermostat housing. Quote Link to comment Share on other sites More sharing options...
Guest Nicholas Posted June 16, 2014 Share Posted June 16, 2014 You must have an air block somewhere Brendan, bleed the system. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 16, 2014 Author Share Posted June 16, 2014 Whats the best way to bleed the system Quote Link to comment Share on other sites More sharing options...
Guest Nicholas Posted June 16, 2014 Share Posted June 16, 2014 Whats the best way to bleed the system Really useful thread here about it, follow both Steve and Ian's instructions and you should be good to go http://www.mkivsupra.net/vbb/showthread.php?126043-Coolant-bleeding Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 16, 2014 Share Posted June 16, 2014 make sure the top pipe is the correct way around. I had one on backwards in the past and the fekker wouldn't bleed. turned it around and fine ... weird Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 16, 2014 Author Share Posted June 16, 2014 Will try that tomorrow now. Still going to replace the rad cap for peace of mind. Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted June 17, 2014 Share Posted June 17, 2014 Replace the Rad cap, is it blowing fluid into the overflow Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 17, 2014 Author Share Posted June 17, 2014 No fluid into overflow. toyota want £27 plus vat for rad cap robbing beeeps. Going to empty my shed to see if I have one knocking about. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted June 17, 2014 Share Posted June 17, 2014 Halfords sell a Rad cap, its 1.1 bar and fits perfectly and I think I paid £8 for it on trade Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted June 17, 2014 Share Posted June 17, 2014 If there is no fluid going into your overflow, then that is not right anyway Give me a call bud, done a lot of messing with Radiators lately Quote Link to comment Share on other sites More sharing options...
jackso11 Posted June 18, 2014 Share Posted June 18, 2014 Just something to check...if you have standard rad and viscous fan there is also a small (maybe 5") fan at the bottom of the rad, electric one. I spent almost £1k changing everything in my cooling system before noticing the tiny fan wasn't working. Changed a fuse (pink one under the bonnet) and have never had overheating problems again. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted June 18, 2014 Share Posted June 18, 2014 Called round to look at the car tonight and lovely looking motor We had a go at bleeding with new cap and heard what sounded like a kettle hissing noise from around thermostat area ,had to leave but Brendan said removed and refitted it but when refilling water dripping from behind water pump to block Now we can only guess that the pump has cracked maybe froze as no antifreeze in it, He is going to remove it and see so he will post up I'm sure later Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 18, 2014 Author Share Posted June 18, 2014 Had emough for tonight, forgot what a pain removing water pump is. Cant believe crank pulley has to be removed just to get one alen key bolt out thst holds the bottom plastics in. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted June 18, 2014 Share Posted June 18, 2014 He'll no Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 18, 2014 Author Share Posted June 18, 2014 He'll no Yep. why did I buy another one again hhhmmmm. Dissy driping oil and has been for a while by looks of it. Rocker cover gasket shot can scrape the cruddy oil off side of the head and the block.car not been cared for for a while, thats for sure. Quote Link to comment Share on other sites More sharing options...
Slam Posted June 19, 2014 Share Posted June 19, 2014 Yep. why did I buy another one again hhhmmmm. Dissy driping oil and has been for a while by looks of it. Rocker cover gasket shot can scrape the cruddy oil off side of the head and the block.car not been cared for for a while, thats for sure. Jasoon had oil from dizzy . Not sure what problem was. Please don't feel bad about another supra mate, sure you will be on the road again soon. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 19, 2014 Author Share Posted June 19, 2014 Just the o ring seal mate Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 19, 2014 Share Posted June 19, 2014 Has the core plug on the water pump backing plate corroded, and is leaking? They see cavitation and erode from the inside out. Quote Link to comment Share on other sites More sharing options...
Shane Posted June 19, 2014 Share Posted June 19, 2014 Brendan, as Chris says it could well be the small core plug at the rear of the NA water pump. You can just about get your hand in and put your finger on the plug and I am sure you will feel it wet there. Its a real common problem on the NA and I had one fail within 18 months of replacing it. I used to have a spare one kicking about but gave it to another member who had the same problem. Doesn't take long to do, it will probably take you longer to find a core plug than doing the job. This thread explains it in more detail: http://www.mkivsupra.net/vbb/showthread.php?270206-Core-Plugs&highlight=core+plug Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 19, 2014 Author Share Posted June 19, 2014 Can the plug be changed in place if the manifolds are moved out of the way. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 19, 2014 Share Posted June 19, 2014 Not a chance, water pump and backing plate need to come off, which is a cambelt off job. I put a new plug in Luiz's engine whilst it was apart. Cheap insurance. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted June 19, 2014 Author Share Posted June 19, 2014 Ahh bummer. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 19, 2014 Share Posted June 19, 2014 The N/A backing plate is different to the TT, and it seems this problem is rare on TT's, but common as muck on the N/A. I'll weigh it up next time I have an N/A pump apart. Quote Link to comment Share on other sites More sharing options...
