bodilx6 Posted June 15, 2014 Share Posted June 15, 2014 6spd, TT, BPU. When doing trackdays and everything is as hot as it gets, my engine lightly stutters and apparently spits a bit of fire when doing so. I'm guessing this is a failed spark and there by unburnt gas in the exhaust. Plugs are iridium and have MAYBE 20k on them, so no gappin'. I'm fairly sure (might be we just fixed them a bit) I got the plastic connectors on the coil packs replaced years back. Can they be causing issues again? Please correct me, if replacing them isn't possible and I'm recalling a dream or something.. If I'm correct though, what would be my next thing to look at? Also, if I inspect the coils, would I risk them crumbling, and then have a stuck car until I get parts? (It's freaking hard to test after, as it ONLY see this on track - for now..) Thanks Quote Link to comment Share on other sites More sharing options...
bignum Posted June 16, 2014 Share Posted June 16, 2014 With any problem like that its a process of elimination, start with the cheapest things 1st, although you can test spark strength by pulling each 1 and laying it on the top of the engine(runing) and connected.it'll be 1 of 3 things, plugs, connectors or coilpack. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 16, 2014 Share Posted June 16, 2014 The plastic coil terminals shells only support, hold and lock the terminals themselves. Toyota do repair terminals with pre crimped terminals on short wires to replace the ones on your own loom, that may well be tired with poor tension. You hould change all twelves and the shells as well if they have gone brittle aging and break when you fiddle with them. Andy Blyth has put the part numbers in the technical resource section. I would say at 20K miles the plugs are due a change. Maybe the coil packs are leaky, but do terminals and plugs first. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted June 16, 2014 Author Share Posted June 16, 2014 Thanks Chris! (Yet again...) This sounds right. It think actually it must be the terminals, I remember having been messed a bit with, point being them lasting a bit longer. We MIGHT have changed them and not just jerry-rigged them, but I don't remember as it was one of the first things I had done to the car 8-9 years back. So, as I understand, I would get terminals with wires that I need to solder in? Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted June 16, 2014 Author Share Posted June 16, 2014 @Bignum; yes, saw that test in the Repair Manual, would like to do that, just need to be sure it all doesn't fall apart when I touch it... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 17, 2014 Share Posted June 17, 2014 Thanks Chris! (Yet again...) This sounds right. It think actually it must be the terminals, I remember having been messed a bit with, point being them lasting a bit longer. We MIGHT have changed them and not just jerry-rigged them, but I don't remember as it was one of the first things I had done to the car 8-9 years back. So, as I understand, I would get terminals with wires that I need to solder in? Raychem adhesive lined, heat shrinkable crimps in the red size are what you need. http://www.ttiinc.com/object/fp_tyco_polycrimp RS Components sell them, and many other electronic supply houses. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted June 17, 2014 Author Share Posted June 17, 2014 Got a bunch of those around! Quote Link to comment Share on other sites More sharing options...
