Skippyboyo1's 2014 build finished LOTS of pics
skippyboyo1
I won't blab on, I've never worked so hard on a car in my life. I've Basicaly gone all out budget wise, but wanted to be different also. I'll add my full spec also at the bottom.
Good or bad comments welcome as always. My paint is like glass but looks dull here for some reason.
Enjoy, will put pics on in blocks of 10 so please wait on comments untill I get all 40 on lol
http://img.tapatalk.com/d/14/06/15/epaha9u2.jpg
http://img.tapatalk.com/d/14/06/15/ynahe8aq.jpg
http://img.tapatalk.com/d/14/06/15/ebusa3am.jpg
http://img.tapatalk.com/d/14/06/15/na4eme4y.jpg
http://img.tapatalk.com/d/14/06/15/a4ututa2.jpg
http://img.tapatalk.com/d/14/06/15/ryquvy6e.jpg
http://img.tapatalk.com/d/14/06/15/u7y3a7y3.jpg
http://img.tapatalk.com/d/14/06/15/hyzany6a.jpg
http://img.tapatalk.com/d/14/06/15/yga5ajyr.jpg
http://img.tapatalk.com/d/14/06/15/mevyva4y.jpg
http://img.tapatalk.com/d/14/06/15/ajave4eg.jpg
http://img.tapatalk.com/d/14/06/15/une9yguv.jpg
http://img.tapatalk.com/d/14/06/15/sa4a5epu.jpg
http://img.tapatalk.com/d/14/06/15/y9ehedup.jpg
http://img.tapatalk.com/d/14/06/15/uzaqupu6.jpg
http://img.tapatalk.com/d/14/06/15/e3e9enud.jpg
http://img.tapatalk.com/d/14/06/15/aju8a5as.jpg
http://img.tapatalk.com/d/14/06/15/ehu2edy3.jpg
http://img.tapatalk.com/d/14/06/15/e3y5eqyn.jpg
http://img.tapatalk.com/d/14/06/15/bunyqy2e.jpg
http://img.tapatalk.com/d/14/06/15/u9asy4ez.jpg
http://img.tapatalk.com/d/14/06/15/ebuza9yb.jpg
http://img.tapatalk.com/d/14/06/15/eru6y2yn.jpg
http://img.tapatalk.com/d/14/06/15/aqejy2ez.jpg
http://img.tapatalk.com/d/14/06/15/aduqa4uq.jpg
http://img.tapatalk.com/d/14/06/15/9a5adege.jpg
http://img.tapatalk.com/d/14/06/15/gegamy9y.jpg
http://img.tapatalk.com/d/14/06/15/ejagy4eg.jpg
http://img.tapatalk.com/d/14/06/15/unu7apeb.jpg
http://img.tapatalk.com/d/14/06/15/avu9e3yz.jpg
http://img.tapatalk.com/d/14/06/15/aju2y8yv.jpg
http://img.tapatalk.com/d/14/06/15/ujusepub.jpg
http://img.tapatalk.com/d/14/06/15/ydyqa8y9.jpg
http://img.tapatalk.com/d/14/06/15/ure6upe2.jpg
http://img.tapatalk.com/d/14/06/15/usyqu5uq.jpg
http://img.tapatalk.com/d/14/06/15/y9avy5e9.jpg
http://img.tapatalk.com/d/14/06/15/e4e5e3yr.jpg
http://img.tapatalk.com/d/14/06/15/u6agyqes.jpg
http://img.tapatalk.com/d/14/06/15/aqa5ameg.jpg
http://img.tapatalk.com/d/14/06/15/ytadyjad.jpg
http://img.tapatalk.com/d/14/06/15/tyqy4yzu.jpg
http://img.tapatalk.com/d/14/06/15/pyna3uhy.jpg
http://img.tapatalk.com/d/14/06/15/ne2epyja.jpg
http://img.tapatalk.com/d/14/06/15/y2ezypyv.jpg
http://img.tapatalk.com/d/14/06/15/huqy3e3e.jpg
http://img.tapatalk.com/d/14/06/15/7useny8y.jpg
http://img.tapatalk.com/d/14/06/15/6a5eza3y.jpg
http://img.tapatalk.com/d/14/06/15/dy3ezu2y.jpg
http://img.tapatalk.com/d/14/06/15/by2utu7u.jpg
http://img.tapatalk.com/d/14/06/15/da7epare.jpg
http://img.tapatalk.com/d/14/06/15/eryza3e9.jpg
http://img.tapatalk.com/d/14/06/15/ybyveraz.jpg
http://img.tapatalk.com/d/14/06/15/7upugy7a.jpg
http://img.tapatalk.com/d/14/06/15/uhypugu6.jpg
http://img.tapatalk.com/d/14/06/15/qapuqade.jpg
http://img.tapatalk.com/d/14/06/15/e6ereqet.jpg
After owning a mk3 Vauxhall Astra with a c20let (Calibra Turbo) engine conversion I decided it was time to move on and get something bomb proof due to reliability issues in the past. A friend of mine is a mechanic at Toyota and recommended the 5speed na supra, I looked at all turbo options however I chose to go for the na simply down to the reliability.I purchaced the car you see now on the 28/07/2005 totaly standard apart from 17" alasio wheels which were fitted. The previous owner to me was actualy the directer of hallmark cards and she imported the car back in 2001 from japan. I used the car as my daily drive which lasted around a year, I then decided to turn it in to a track car for the following 3 years where the car proved how reliable it was. I then decided to make it in to the car you see now..... Trackdays are now a thing of the past.
Engine:
- JZA80, J spec,5 speed manual
- High lift cams (fitted in japan)
- Carbon fiber fuse box lid/ clear coated (small twill weave)
- Igniter relocated
- Engine covers painted 202 black
- Bonnet sound proofing removed
- Optima red top battery RTC 4.2
- Extended battery wires and uprated terminals
Exhaust:
- Straight through 2.5" custom system by custom pipes,no cats and one middle box with race manifold/ 4 inch exit pipe with removable baffle if needed
- vortex technology silencers
- All brackets hiden
Drivechain:
- Uprated diff to 99 turbo (after smashing 3 standard ones in it's previous life as a track car with me, see pic above)
Weight reduction:
- OEM front seat belts and plugs removed
- OEM rear seat belts and plugs removed
- Spare wheel removed with all associated tools
- carbon boot (see info below)
- carbon wings (see info below)
- carbon seats (see info below)
Suspension, Wheels, Tires & Brakes:
- Bc racing adjustable Coilovers (RM Series)
- Rota Tourque 18",Falcon Tyres 275 Rear and 235 Front
- Black wheel nuts all round
- Calipers painted 202 black all round
Interiour & ICE
- Flocked main dash (OEM dashboard tweeter speakers removed and filled)
- Flocked upper and lower glove boxes (in and out inc handles)
- Flocked Door cards
- Flocked front speaker covers
- Flocked Door Handle surrounds
- Flocked top dash vent (drivers side)
- Flocked steering Collum cover
- Flocked A pillars
- Flocked driver/Passenger left and right kick plates inc linking strips both sides
- Flocked rear window surround (seat belt holes removed/smoothed)
- Flocked Rear pannels/speaker surrounds
- Flocked top boot panel (located under spoiler)
- Flocked front center Arm rest (in and out)
- Flocked boot panels x3 (all above in black 1mm)
- Carbon fiber sound system/clear coated (small twill weave)
- Carbon Fiber gear surround, Ash tray removed and smoothed out (small twill weave clear coated)
- Carbon Fiber main dash,3 blanks smoothed,Cigarette lighter smoothed,(small twill weave clear coated)
- Carbon Fiber dial surrounds (small twill weave, clear coated)
- Carbon Fiber right hand dash panel, Dash dimmer switch smoothed (small twill weave, clear coated)
- Carbon Fiber warning light surround dash panel (small twill weave, clear coated)
- Carbon Fiber passenger door window switch, Fully custom made (small twill weave, clear coated)
- Carbon Fiber boot pannels x2 linking to the rear seats (small twill weave, clear coated)
- Carbon Fiber cusco Strut Brace (Custom fit) small twill weave unlaquered
- Carbon Fiber Corbeau race seats XL x2 with custom designed red stitching And matching red "corbeau " logo, "pro series logo finished in black (6kg per seat)
- Boot light air vent removed, filled, flocked
- Center arm rest lid modified with custom fitted Uprated metal brackets.
- Ammeter built into soundsystem with Uprated led lighting fitted with custom internal shunt. (Hiden)
- Custom built/mounted floating amp finished in Matt black
- Custom fitted bass ports x2 3" vibe units finished in chrome and black (front facing)
- Led instrument lighting conversion with PCB main dials (all in Ice white)
- Cigaret lighter re located to drivers footwell (custom aluminium bracket) illumination light removed.
- Omex 22 5 stage Shift light (dash mounted with adjuster in drivers footwell
- Dash light dimmer switch relocated to drivers footwell
- Black leather roof lining with black sun visors and matching interior light fitted with LED boards x2 (super bright ice white)
- Black main carpet
- Boot carpet modified to fit sound system,tension set and rear strut brace (custom plastic underlay to fit the same)
- Car fully sound deadned inc roof/floor/doors
- Extra OEM sound deadning added behind all standard interior pannels
- Horn switch relocated to steering Collum (hiden)
- Center dash blower removed and fitted with vault meter (analog)
- Corbeau Aluminium seat mounts (black) with chrome logos
- Uprated nut (locking) and bolt combo (Above seat mounts adapted for this)
- Custom super low seat floor mounts (black steel)
- Custom rear seats (black kangaroo leather with red stitching) with Rear seat belt holes removed
- Custom retrimed driver/passenger door arm rests (black kangaroo leather with red stitching)
- Sabelt 4 point harnesses (pads removed) attached to custom harness bar, 4x aluminium 3 bar slides (see do luck tension set info)
- Full custom sound system designed and built by me.(as above)
- X4 infinity crossovers
- kenwood 17cm rear speakers (3 way)
- kenwood 17cm front speakers (3 way),custom SRD mounts/OEM standard boxes removed
- Audison Amp (floating)
- JL Audio 12" sub
- Audison high power, powercap (hiden, located in the boot)
- 0 gauge power wire, x2 inline 60 amp fuses (located at battery and boot)
- OMP Corsica 95mm Deep dish steering wheel (black leather with red stitching/centre stripe)
- Leather gear gator black with red stitching
- Leather handbrake gator black with red stitching
- Original black Supra Mats (Black supra logo)
- Original Do luck aluminium tension set with custom made harness bar alluminium welded with standard brackets removed, do luck logos removed, finished in a fully mirror polish.
- Fire extinguisher mounted to tension set
- pioneer sph100 head unit (updated to iPhone 5 spec with leads ) with custom handbrake mod to allow movies in motion ,7" screen" with hiden satellite navigation areal.
Exteriour:
- Facelift headlights
- Xenon HID 4300k (legal, but also have 8000 if the mood takes me) fitted to dipped beam (hiden boxes)
- Facelift rear lights
- Uprated LED rear reg plate lights x2 in super bright ice white
- Black gloss (low shine) finished wiper arms
- Bosch super streamline aero wiper blades
- New Toyota rear window seal
- New Toyota front window seal
- Smoked side repeaters
- Front bumper indicators removed
- Front foglights now LED indicators (in facelift headlights)
- Rear Supra badge removed
- Rear Toyota badge removed
- Front Toyota badge removed
- Front reg plate relocated
- Front reg plate holder removed
- Front reg plate holes smoothed over
- Front reg plate printed on stick on transfer mounted on bottom front lip
- My name in carbon gap in paint on carbon boot "designed and built by C.T.Hudson"
- Aerial Removed and smoothed over
- Rear wiper and motor removed
- Front washer jets removed and smoothed over
- Rear washer piping re routed to front washers (see below)
- Custom fitted made/fitted hiden front washer jets under scuttle pannel (2014 VW golf wide spray)
- Modified OEM scuttle pannel (sits 4mm higher than Standard to encorporate washer jets)
- Carbon fiber 1 off custom wings (small twill, painted 202 black with carbon "RT- Autobodies.co.uk" visible through paint.
- Carbon fiber custom boot lid 1 off (small twill,painted 202 black) wiper hole and rear washer hole removed in this process
- Carbon fiber custom canards x4 un laquered bare carbon (large twill weave) design commissioned by me.
- OEM Toyota rear spats fitted (plastic)
- OEM Toyota Side skirts fitted (plastic)
- Front bumper modified/strengthened and black meshed with lower lip spoiler, with ears (Imported from California)
- Full re-spray in Toyota Black finished in July 2011
- Bonnet vents cut into standard holes and meshed in black to match front bumper
- All 4 arches rolled (re painted)
- Fuel tank cover powder coated (Black)
- Uprated droplinks fitted
- Shine Auto Full carbon diffuser without end plates fitted (screwed...then bonded to avoid gravel degradation)
Proven Performance
Max speed - 164 mph (on limiter in 5th)
Quarter mile 14.31 @ 95.41mph (fastest na in the uk with no noz)
With thanks to....
Corbeau Road and Race uk (Matthew)
R.T Autobodies Leeds (Richard tremlin)
Mark Hedley (Burrows Toyota)
Custom pipes Doncaster (Ryan)
Extream performance uk (Keiron)
Bielawski's upholsteres Sheffield
Yorkshire metal finishers ltd Leeds
Floc-king.co.uk
Source Sounds (Sheffield)
mkivsupra.net
Currently fastest NA in the hall of fame quarter mile times with no noz with 14.31 @ 95.41MPH
My build can be found here.........
http://www.mkivsupra.net/vbb/showthread.php?243035-My-JZA80-coming-back-to-life-project
Alright guys, bloody hell I've had a few pm's about carbon I'll try and answer them all on here in 1 go.
Carbon is horrible to work with, it hates to bend, it won't go round corners and is an all round pig. There's a Traider on here who does carbon and I'm sure he will agree. One thing I also need to point out is for around a year I've had this planned and researched all options available. There was a guy on here from Ireland that claimed to do all the dash pannels for £300, if that's the case I'll take 10 sets right now as that price is way too low.
To get the finish I have has not been easy to say the least. I spent 3 solid days rubbing the pannels down alone. Then they need painting with black apoxy resin and then the fun starts, you have to lay the carbon on the parts getting in to all the contours etc and apply apoxy resin.... Then in to a vac bag to get all the resin to penitrate the carbon, then under a heat lamp to dry, once dry the parts need rubbing down then more resin and repeat the process.... Mine has 5 coats. Then the final rub down and clear coat. The clear coat is then rubbed down and clear coated again and repeat until you get a good finish. My dash pannels have around 40 hours of work in them, the sound system just to carbon has around 15.
Ok so where did I get it done, there's no point in saying to be honest, it was a good friend of mine but to make it worth him doing the dash pannels would be around the 1k mark easy (just for dash pannels) plus said he wouldn't want to do it again . My bill at mates rates for all this was the price of a small car and that's mates rates.
Carbon is super super expensive a total ball ach but obviously people love it but also have no idea how complex it is.
To get it cheep I hear the best way is to send your bits off to china as it's cheep labour.
Edited by skippyboyo1 (see edit history)
