theredone Posted June 14, 2014 Share Posted June 14, 2014 Does anyone know the colour of the wires that plug into the key barrall 12v + constant ig2 output ig1 output ive got to hard wire in my turbo timer as they dont make an harness for the na Quote Link to comment Share on other sites More sharing options...
Kev.O Posted June 14, 2014 Share Posted June 14, 2014 12v + constant fed from fuse AM1 that is for IG1 - White IG1 output - Black and Yellow 12v + constant fed from fuse AM2 that is for IG2 - White and Red IG2 output - Black and White Quote Link to comment Share on other sites More sharing options...
theredone Posted June 14, 2014 Author Share Posted June 14, 2014 Thanks but i only have 3 wires, one 12 volt constant feed which ill need and one that goes to a ig1 wire and one that goes to a ig2 wire so the 12 volt goes to the red and white wire? Quote Link to comment Share on other sites More sharing options...
Kev.O Posted June 15, 2014 Share Posted June 15, 2014 What about a negative? Either the white or white and red will provide a permanent 12 volts. Quote Link to comment Share on other sites More sharing options...
theredone Posted June 16, 2014 Author Share Posted June 16, 2014 The fitting guide says the negative goes into the back of the ecu and cheers for the info Quote Link to comment Share on other sites More sharing options...
