Scott Posted June 14, 2014 Share Posted June 14, 2014 It depends what way you hold the line lock around though. If the way you have it is considered upside down then it would be the other way around. I'm almost positive it goes the other way mate. Try it, if it solves your problem you have the answer Quote Link to comment Share on other sites More sharing options...
drift_bear Posted June 14, 2014 Author Share Posted June 14, 2014 (edited) It depends what way you hold the line lock around though. If the way you have it is considered upside down then it would be the other way around. I'm almost positive it goes the other way mate. Try it, if it solves your problem you have the answer Obviously it's came from Titan so it's mainly used on a LHD supra, didn't think it would cause problems by just switching sides? Are you saying switch the 2 lines around in the solenoid only? My front brakes don't need looked at cause they are fine and stop on the dot, only fitted them a month ago lol, came from a member on here.. Edited June 14, 2014 by drift_bear (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted June 14, 2014 Share Posted June 14, 2014 Obviously it's came from Titan so it's mainly used on a LHD supra, didn't think it would cause problems by just switching sides? Are you saying switch the 2 lines around in the solenoid only? Yes, just on the solenoid mate. Definitely won't cause any issues. The issue you are seeing is exactly what I would expect if it's a 1 way check solenoid and it was the wrong way around. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted June 14, 2014 Author Share Posted June 14, 2014 Yes, just on the solenoid mate. Definitely won't cause any issues. The issue you are seeing is exactly what I would expect if it's a 1 way check solenoid and it was the wrong way around. I feel stupid now! That's it changed over and working now dude Quote Link to comment Share on other sites More sharing options...
Scott Posted June 14, 2014 Share Posted June 14, 2014 I feel stupid now! That's it changed over and working now dude As I said.... operator error Quote Link to comment Share on other sites More sharing options...
drift_bear Posted June 14, 2014 Author Share Posted June 14, 2014 I feel stupid now! That's it changed over and working now dude :p Quote Link to comment Share on other sites More sharing options...
Scott Posted June 14, 2014 Share Posted June 14, 2014 Make sure you got all of the brake fluid off mate. It's a fantastic paint stripper. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted June 14, 2014 Author Share Posted June 14, 2014 Make sure you got all of the brake fluid off mate. It's a fantastic paint stripper. Once I changed the lines over, I wiped everything down with a damp cloth then a microfibre Quote Link to comment Share on other sites More sharing options...
Pig Posted June 15, 2014 Share Posted June 15, 2014 On the pictures it looks like it's not installed correctly. I am not at home but when I am back in the next few days I will send you a pic of how mine is installed and works perfectly. If you can hear he solenoid click then it won't be that IMO. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted June 15, 2014 Author Share Posted June 15, 2014 On the pictures it looks like it's not installed correctly. I am not at home but when I am back in the next few days I will send you a pic of how mine is installed and works perfectly. If you can hear he solenoid click then it won't be that IMO. It's ok Jon, it's all working now Quote Link to comment Share on other sites More sharing options...
Scott Posted June 15, 2014 Share Posted June 15, 2014 Out of curiosity mate, are the holes to mount it already there or did you have to drill them? Quote Link to comment Share on other sites More sharing options...
drift_bear Posted June 15, 2014 Author Share Posted June 15, 2014 Out of curiosity mate, are the holes to mount it already there or did you have to drill them? Because I tidied up my engine may abit when it was at SRD, I have a few extra holes in my engine bay. Luckily I had ones up there by the master cylinder and they were the correct size for the kit Quote Link to comment Share on other sites More sharing options...
Scott Posted June 15, 2014 Share Posted June 15, 2014 Because I tidied up my engine may abit when it was at SRD, I have a few extra holes in my engine bay. Luckily I had ones up there by the master cylinder and they were the correct size for the kit Coolio, will have a look Quote Link to comment Share on other sites More sharing options...
drift_bear Posted June 15, 2014 Author Share Posted June 15, 2014 http://img.tapatalk.com/d/14/06/15/8e6e3ame.jpg That's how much space lol Quote Link to comment Share on other sites More sharing options...
