Brakes squishy even after reccomended upgrades
bodilx6
I've upgraded to 4/2 pot brakes, have TRD rotors as well as braided lines and fast road car pads from Chris Wilson. Also 300+ degree c brake fluid and the brake cylinder brace.
I still fell squishy brakes after a few corners on track. Never on the road though. When I get the (used) set of brakes, I fully renovated them but the squishiness have been constant. Actually I have cone back to OEM pads, as they have a better feel on regular roads, but doesn't not work optimally on track either.
I've run with or without shims, same result.
Any ideas where to go next? As far as I can figure, I should not need to go with a big brake upgrade, as my driving on track is not aggressive nor often enough for this to be needed. Two times a year to the Ring and two - three trackdays is all.
As my issues shows themselves within a very short distance on track, I'm guessing I can eliminate it being be over braking. I never go aggressively in brakes (as instructors usually tells me to do) to avoid the fade.
Except checking for seized calipers (which should be weird, as problem has been constant for years since renovation and they were sliding nicely then) can anyone come up it any other ideas?
By the way, I'm going to Orlando and Titan Motorsports later this year, so should I feel rich, does anyone know how large brakes the 18" TTE/Lexus wheels will take? (I will probably avoid this, as non-stock brakes are illegal in dk)
Thanks!
I've notice a bit of travel in my brake pedal, I wouldn't call it squishy exactly but the brakes are not immediate with the first bit of movement of the pedal.
I personally don't mind this feeling but I'd imagine it's down to the car's original brake master cylinder being mismatched to the 4/2 pot calipers I fitted.
The master cylinder designed for the 4/2 calipers is a slightly bigger diameter than the unit fitted to a car with 2/1 calipers, so the smaller piston in the smaller cylinder must travel further to push enough fluid into the larger calipers to produce adequate braking force. The further the piston moves the further the pedal must move.
Could this be the case here?
Pad knock back, the front uprights on 95% of road cars are as stiff as a rubber band when given a proper work out on a race track. They bend and the disc pushes the pads back a tiny amount, so the next brake application needs to take up this excessive pad to disc clearance. Race uprights have a stub axle (where the wheel bearings sit) of over 2 inch OD, the Supra just over one inch, with similar disparity in hub bearing sizes). Road car suspension design is usually shown inadequate on track. This is one reason race cars use floating discs where regulations allow. You can add light springs behind the pistons, inside the calipers. AP racing sell them in sizes that may fit. These pre-load the pads slightly. Running *NO* anti squeal shims, and *NO* anti rattle junk may also help, albeit they'll probably rattle on rough road surfaces. It may also help to ensure the master cylinder cap is breathing properly, and the master cylinder is utterly clean with no sediment in the bleed back hole (rebuild it after blowing out with brake cleaner and an air line, using new seals).
Can you do a left foot brake tap near the end of a straight like the Aussie V8 supercar guys do? :)
Thanks Chris, I was hoping you would chime in...
So, you are saying (ignoring the possible sediment and master cylinder breathing issues), that all supras have soft brakes even before any real heat get in there? And without non-realistic (for a road car) upgrades and costs, it is the way it is?
So if you would install huge look-at-me-bling-bing-12-caliper-insane-brakes, you would still have this issue, except it would never translate into actual fade as the 4/2 brakes can do if you really go at it?
This is bad news as it gets really hard to heel and toe when braking hard into corners..
They are no better or worse than most road cars used on track. If you spend a huge amount on an aftermarket kit I would make sure it had floating discs. Pad knock back is usually mild and just gives slightly longer pedal travel on the first brake application after a hard cornering manoeuvre. Your problem sounds more excessive than that, if I read it right?
I think it is, as the pedaltravel i probably double than it is on road/before any usage. But I will definatly think about what you are saying. I will not spend £££ on a crazy brake setup, as my entire plan has been to keep the car stock looking. However, if it was the only way to really enjoy it on track, i might do it. But I will check seized pistons, master cylinder breathing and gunk before going forwards.
/Stefan
