ccssupra Posted June 13, 2014 Share Posted June 13, 2014 Hi Guys, got the following: Exhaust with double Decat Walbro 255 NGK Iridium plugs HKS FCD 1 bar Restrictor ring The Jspec turbos can achieve 1.2 bar, is the best way to achieve this to remove the restrictor ring, and then control it via Boost controller? I was always unsure if the restrictor ring should still be in place, then using the BC to increase to 1.2... Thanks, Link to comment Share on other sites More sharing options...
listy Posted June 13, 2014 Share Posted June 13, 2014 Leave the restrictor ring in. You raise boost with the boost controller, but you can't lower it. Link to comment Share on other sites More sharing options...
ccssupra Posted June 13, 2014 Author Share Posted June 13, 2014 Cool, thats all I wanted to know, thanks listy! Link to comment Share on other sites More sharing options...
