Philly_1 Lex Posted June 11, 2014 Share Posted June 11, 2014 Hello, Just wondering if anyone knows proper trailer size to tow a supra? (8 or 10ft) Next best tow points to for a Supra. Any tips for towing behind an estate? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 12, 2014 Share Posted June 12, 2014 Google translate didn't help. Nor did reading it backwards. Please try again. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted June 12, 2014 Share Posted June 12, 2014 (edited) Just wondering if anyone knows proper trailer size to tow a supra? (8 or 10ft) - 14ft long and a minimum of 6ft wide is about as small a trailer that can comfortably take a Supra Next best tow points to for a Supra. - If you are referring to the best method of tying it down on a trailer then the proper wheel straps are the best for any vehicle Any tips for towing behind an estate? - Not really advised as the towed weight is significant. A large Merc or Audi estate would probably work if desperate, but a large van or jeep is recommended. My outfit Edited June 12, 2014 by pedrosixfour (see edit history) Quote Link to comment Share on other sites More sharing options...
Philly_1 Lex Posted June 12, 2014 Author Share Posted June 12, 2014 pedrosixfour said: Just wondering if anyone knows proper trailer size to tow a supra? (8 or 10ft) - 14ft long and a minimum of 6ft wide is about as small a trailer that can comfortably take a Supra Next best tow points to for a Supra. - If you are referring to the best method of tying it down on a trailer then the proper wheel straps are the best for any vehicle Any tips for towing behind an estate? - Not really advised as the towed weight is significant. A large Merc or Audi estate would probably work if desperate, but a large van or jeep is recommended. My outfit http://www.mkivsupra.net/vbb/attachment.php?attachmentid=185623&d=1400166200 Pedro exactly what looking for. Cheers mate. Chris sorry I confused you. Quote Link to comment Share on other sites More sharing options...
SPG Posted June 12, 2014 Share Posted June 12, 2014 Philly make sure you check the maximum towing ability of the estate you are using, the sup and trailer will be around 2tones alone Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 12, 2014 Share Posted June 12, 2014 The problem is you need a LOOOONG trailer as you need to keep the car fairly far back to keep the nose weight sane for a lightweight towing vehicle to handle. Otherwise, if the bumper is nearly over the tow hitch the nose weight is such the front wheels of the tow car will be pawing the air and it will be dire to drive, if not downright dangerous. It's not hard to confuse me, no apologies needed Quote Link to comment Share on other sites More sharing options...
