walkerstrider Posted June 11, 2014 Share Posted June 11, 2014 (edited) How long will it take to swap over cross member on my driveway? Its the steel one atvthe back of the engine. On axel stands. Its a n/a. Is it a difficult job? Cheers in advance Edited June 11, 2014 by walkerstrider (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted June 12, 2014 Share Posted June 12, 2014 Should be pretty easy as long as all the bolts come out ok, the problem ones are the camber adjusting bolts that connect the bottom arms, spray plenty of penetrating lube around them beforehand. Quote Link to comment Share on other sites More sharing options...
Guest FullAttack Posted June 14, 2014 Share Posted June 14, 2014 spray plenty of penetrating lube around them beforehand. Everyday for a week! Quote Link to comment Share on other sites More sharing options...
Ric Posted June 14, 2014 Share Posted June 14, 2014 Isn't the front crossmember spot welded to the chassis? But that's at the front of the engine which houses the radiator. I assume you are talking about something else Quote Link to comment Share on other sites More sharing options...
Guest FullAttack Posted June 15, 2014 Share Posted June 15, 2014 Isn't the front crossmember spot welded to the chassis? But that's at the front of the engine which houses the radiator. I assume you are talking about something else Different bit man.. That front bit is welded.. The sub-subframe is behind the sump.. It's a pretty easy job.. Why do you need to do it by the way, can't imagine they break? Quote Link to comment Share on other sites More sharing options...
Ric Posted June 15, 2014 Share Posted June 15, 2014 I know the subframe is easy to remove but he didn't ask for that did he.. Hence the question Quote Link to comment Share on other sites More sharing options...
bignum Posted June 15, 2014 Share Posted June 15, 2014 He said in another thread its rusted pretty bad. Quote Link to comment Share on other sites More sharing options...
