SupraP-Z Posted June 10, 2014 Share Posted June 10, 2014 So ive taken out the grey carpet in mine, and before I dye it, I want to give it a thorough clean. What do you guys recommend? Im after something that isn't too expensive, and can be done by hand? Ive found some stuff on ebay - the valeters pride stuff which looks ok, but it says for use with machine because its low foam? Any others you guys have tried and tested? Link to comment Share on other sites More sharing options...
David P Posted June 10, 2014 Share Posted June 10, 2014 I just gave mine a blasting with a soapy jet wash. Link to comment Share on other sites More sharing options...
Ric Posted June 10, 2014 Share Posted June 10, 2014 i used some left over carpet wash from asda, does the job, just make sure you use a proper extractor to get the water out or it will mould instead of drying Link to comment Share on other sites More sharing options...
Dim Sum Posted June 10, 2014 Share Posted June 10, 2014 Spray some chemical guys carpet/stain remover then use a wet - vac. Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 10, 2014 Share Posted June 10, 2014 I just jet washed mine Link to comment Share on other sites More sharing options...
