Still Not Right
Guest Jason1
Guest Jason1
Hi folks
I am sure my turbos aren't running right
I did a bit of work on the car yesterday, fitted billstein shocks (thanks to a member on here)
and I was surprised on how much stuff was loose on the car, Bottom ball joints weren't even tight? No wonder I had a few rattles
Also now full 3" system fitted.
Anyway now the car handles as it should I decided to have a spirited drive and I can just not feel any dip or a shove from the second turbo?
I have checked all connections, hoses etc and cannot find fault with anything.
If I drive the car (auto) I just get a pull from 3k right through. At 3k .0bar, at 3.5k .5bar and at 4k .9bar.
This is steady acceleration
However If I floor it then a boost spike to a bar the back down to .7bar then it will settle at .9bar
Does this seem right as I am not sure
Thanks
The first turbo should be coming in at around 1.8K rpm the 2nd turbo at around 3.5K rpm, from your description it sounds like both turbos are set up to run in parallel.
Here are some threads in the FAQ section that may be of help.
http://www.mkivsupra.net/vbb/showthread.php?35924-Sequential-turbo-hoses&highlight=sequential
http://www.mkivsupra.net/vbb/showthread.php?35926-The-sequential-system&highlight=sequential
http://www.mkivsupra.net/vbb/showthread.php?27904-Sequential-turbo-problems&highlight=sequential
Guest Jason1
Thanks for that
I have checked the vac lines and the operation of the Exhaust valve and they seem to be all good.
Could it be possible that a vsv or similar has given up and I am only using one turbo?
Guest Jason1
Ok
Now I have run the car in ttc mode and I hit 1.2 bar then
straight back down to .9bar
I think this is correct as I have a exhaust restrictor fitted
So turbos good?
I have put it back to how it should be and it us the same as
before, any chance a vsv is stopping one if the turbos working
correctly?
