jza800 Posted June 7, 2014 Share Posted June 7, 2014 I got a customer car in the shop, with a strange boost problem, the Whole engine is close til stock.. the only thing is a fcd wirred to the map sensor... but at wot it boost 1.2 bar.. there is no boostcontroller on the car, and the front cat is still in place, how is it posible that it can boost 1.2 bar??? Quote Link to comment Share on other sites More sharing options...
Scott Posted June 7, 2014 Share Posted June 7, 2014 Check if there is a mines ECU in there. There is also the possibility of a gutted first cat. Quote Link to comment Share on other sites More sharing options...
jza800 Posted June 7, 2014 Author Share Posted June 7, 2014 but can the mines ecu raise the boost without a boost controller... Quote Link to comment Share on other sites More sharing options...
Scott Posted June 7, 2014 Share Posted June 7, 2014 but can the mines ecu raise the boost without a boost controller... Do you think I'm making it up? Quote Link to comment Share on other sites More sharing options...
jza800 Posted June 7, 2014 Author Share Posted June 7, 2014 no it was just a questions . i will check up on it, and get back to you.. Quote Link to comment Share on other sites More sharing options...
jza800 Posted June 8, 2014 Author Share Posted June 8, 2014 i have now looked af the car Again, and there is no mines ecu on the car.. and if there was a mines ecu, it should not be nessary with the fcd, as the mines has removed that in the ecu right?????? Quote Link to comment Share on other sites More sharing options...
Scott Posted June 8, 2014 Share Posted June 8, 2014 Indeed, but stranger things have happened. With no aftermarket ECU in place then it sounds like either there is a faulty VSV or the 1st cat has been gutted. Quote Link to comment Share on other sites More sharing options...
jza800 Posted June 9, 2014 Author Share Posted June 9, 2014 took a drive in the car, to see how it acked. and the 1st turbo boost 0.7 bar, and around 3.5 -4000 rpm, when the 2nd turbo kicks in it peak to 1.2 bar , and then drop to 1.0 bar at the end off the rpm range... so is it a vsv problem or cats problem? or can it be both??? Quote Link to comment Share on other sites More sharing options...
Scott Posted June 9, 2014 Share Posted June 9, 2014 Check and see if you can spot a restrictor ring between the 1st and second cats. If you can't then it's likely a VSV issue but it's tough to tell without taking the cat off. Some people take the cat off to knock out the innards, so that they don't need to use a decat pipe..... that's what I meant by gutted.. rather than broken - - - Updated - - - Are you 100% certain there isn't a manual boost controller attached? Quote Link to comment Share on other sites More sharing options...
