cainhead Posted June 4, 2014 Share Posted June 4, 2014 Can anyone answer this please as I have one for sale and need to know if my UK will fit a JDM. Cheers Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted June 4, 2014 Share Posted June 4, 2014 Pretty sure they are the same, the first is a different pattern to the manifold. Quote Link to comment Share on other sites More sharing options...
cainhead Posted June 4, 2014 Author Share Posted June 4, 2014 I also thought they were, however I remember having to check the UK box on the whifbitz website when I bought it which was £10 more the JDM. Quote Link to comment Share on other sites More sharing options...
Marty Posted June 5, 2014 Share Posted June 5, 2014 A uk will fit a jdm, but you'll have to tie up a sensor that would normally fit in to a jap spec cat (uk cat doesn't have the hole for it). It's a cat temp sensor or something similar. My mate has my old uk spec cat fitted to his j-spec. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted June 5, 2014 Share Posted June 5, 2014 A uk will fit a jdm, but you'll have to tie up a sensor that would normally fit in to a jap spec cat (uk cat doesn't have the hole for it). It's a cat temp sensor or something similar. My mate has my old uk spec cat fitted to his j-spec. The cat temp sensor fits into the first cat, which is different from UK to JDM and also TT, to NA:) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 5, 2014 Share Posted June 5, 2014 A UK spec 2nd decat pipe will have a port for the 2nd O2 sensor. It will fit a none UK car, but you need to blank the port, for which I sell a proper adaptor plate and screw in bung. Quote Link to comment Share on other sites More sharing options...
