MattP Posted June 4, 2014 Share Posted June 4, 2014 (edited) After having a look through the forum I notice this has been asked before but remains relatively unanswered so maybe this time a few of you will pitch in.... PLEASE POST: FULL BPU Lo/Hi parameter settings Gain Settings for Lo/Hi Engine your using IE: VVTI or not Auto/Manual Turbos: UK/J-Spec/Hybrids Injectors:UK/J-spec/Other I am expecting very varied settings from car to car so don't be shy..... Edited June 4, 2014 by MattP (see edit history) Link to comment Share on other sites More sharing options...
dannysupratt Posted June 4, 2014 Share Posted June 4, 2014 Which profec 2 is it? I've got the new oled one on my vvti but it is set up slightly different to the older one I think. Link to comment Share on other sites More sharing options...
MattP Posted June 4, 2014 Author Share Posted June 4, 2014 Which profec 2 is it? I've got the new oled one on my vvti but it is set up slightly different to the older one I think. Amended Link to comment Share on other sites More sharing options...
Luxluc Posted June 4, 2014 Share Posted June 4, 2014 When I was BPU on euro-spec turbos (non-VVTi, V160, euro-spec 550 injectors), my low boost setting was 1.2, high boost 1.4 Link to comment Share on other sites More sharing options...
MattP Posted June 4, 2014 Author Share Posted June 4, 2014 When I was BPU on euro-spec turbos (non-VVTi, V160, euro-spec 550 injectors), my low boost setting was 1.2, high boost 1.4 What were your gain settings at Hi/Low? Link to comment Share on other sites More sharing options...
Luxluc Posted June 4, 2014 Share Posted June 4, 2014 What were your gain settings at Hi/Low? Sorry .. too long ago mate. Don't know. Link to comment Share on other sites More sharing options...
MattP Posted June 4, 2014 Author Share Posted June 4, 2014 Sad face Link to comment Share on other sites More sharing options...
Marcus GTE Posted June 4, 2014 Share Posted June 4, 2014 I would be interested to know the settings for this too. Quite a popular ebc, so I'd be surprised if nobody knew what settings to use. Link to comment Share on other sites More sharing options...
Westy Posted June 4, 2014 Share Posted June 4, 2014 FULL BPU Lo/Hi parameter settings: 0.8 bar/1.2 bar Gain Settings for Lo/Hi: 5%/25% Engine: VVTI 6 speed Manual Turbos: J-Spec Injectors: J-spec Link to comment Share on other sites More sharing options...
MattP Posted June 4, 2014 Author Share Posted June 4, 2014 FULL BPU Lo/Hi parameter settings: 0.8 bar/1.2 bar Gain Settings for Lo/Hi: 5%/25% Engine: VVTI 6 speed Manual Turbos: J-Spec Injectors: J-spec keep them coming Link to comment Share on other sites More sharing options...
MattP Posted June 4, 2014 Author Share Posted June 4, 2014 come on there must be more of you Link to comment Share on other sites More sharing options...
Marcus GTE Posted June 4, 2014 Share Posted June 4, 2014 FULL BPU Lo/Hi parameter settings: 0.8 bar/1.2 bar Gain Settings for Lo/Hi: 5%/25% Engine: VVTI 6 speed Manual Turbos: J-Spec Injectors: J-spec Good info Think I'll go with it for my UK twins when I eventually get round to getting it fitted. I know they can go to 1.4 but I'd rather play safe and see what 1.2 is like. Link to comment Share on other sites More sharing options...
MattP Posted June 4, 2014 Author Share Posted June 4, 2014 well this has been a disaster lol Link to comment Share on other sites More sharing options...
spikedjack Posted June 4, 2014 Share Posted June 4, 2014 I'll post tomorrow when I drive it to mot! Link to comment Share on other sites More sharing options...
MattP Posted June 4, 2014 Author Share Posted June 4, 2014 I'll post tomorrow when I drive it to mot! Victory Link to comment Share on other sites More sharing options...
MattP Posted June 5, 2014 Author Share Posted June 5, 2014 Come on you lot there's loads of you with this controller at BPU Participate..... Link to comment Share on other sites More sharing options...
spikedjack Posted June 6, 2014 Share Posted June 6, 2014 Doh! Forgot to look! I know it's set to 1.2bar and 52% on the one setting hi Gain rings a bell at 25% also Link to comment Share on other sites More sharing options...
MattP Posted June 6, 2014 Author Share Posted June 6, 2014 Excellent that sounds similar to mine at Hi get your full settings listed Matey Link to comment Share on other sites More sharing options...
gaijin Posted June 6, 2014 Share Posted June 6, 2014 Try these Had these settings on hybrids High: Set-57 Gain-35 Set Gain-86 Low: Set-37 Gain-30 Set Gain-55 Move the settings by 2 points up or down if these don't work out It takes a while,and good weather,to reach what you want Good luck Link to comment Share on other sites More sharing options...
MattP Posted June 6, 2014 Author Share Posted June 6, 2014 Try these Had these settings on hybrids High: Set-57 Gain-35 Set Gain-86 Low: Set-37 Gain-30 Set Gain-55 Move the settings by 2 points up or down if these don't work out It takes a while,and good weather,to reach what you want Good luck Excellent thats what I like to see I will post mine this weekend when I can set it up properly. As I said this thread is for people to be able to search and compare settings they will all be different but for people setting up there Controller it ensures they have an idea of where they can go with the settings. Link to comment Share on other sites More sharing options...
gaijin Posted June 6, 2014 Share Posted June 6, 2014 If it's any use I have a record of every time I changed the settings and to what too Nearly 8 years of settings They have now changed as I run a gt35 single Keep twiddling Link to comment Share on other sites More sharing options...
MattP Posted June 6, 2014 Author Share Posted June 6, 2014 If it's any use I have a record of every time I changed the settings and to what too Nearly 8 years of settings They have now changed as I run a gt35 single Keep twiddling It would help greatly yes if you can post or email me a copy il post them for you Link to comment Share on other sites More sharing options...
Littler Posted June 6, 2014 Share Posted June 6, 2014 If you want more PM supraleeturbo for the settings on my old car Non-vvti auto, low boost was 1 bar and high was 1.1 bar but I can't for the life of me remember the settings Link to comment Share on other sites More sharing options...
MattP Posted June 6, 2014 Author Share Posted June 6, 2014 If you want more PM supraleeturbo for the settings on my old car Non-vvti auto, low boost was 1 bar and high was 1.1 bar but I can't for the life of me remember the settings Very good sir Link to comment Share on other sites More sharing options...
Supraleeturbo Posted June 6, 2014 Share Posted June 6, 2014 Will let you no when I next get her out the garage Link to comment Share on other sites More sharing options...
