Greddy Profec B Spec 2 boost controller settings
MattP
After having a look through the forum I notice this has been asked before but remains relatively unanswered so maybe this time a few of you will pitch in....
PLEASE POST:
FULL BPU Lo/Hi parameter settings
Gain Settings for Lo/Hi
Engine your using IE: VVTI or not
Auto/Manual
Turbos: UK/J-Spec/Hybrids
Injectors:UK/J-spec/Other
I am expecting very varied settings from car to car so don't be shy.....
Edited by MattP (see edit history)
FULL BPU Lo/Hi parameter settings: 0.8 bar/1.2 bar
Gain Settings for Lo/Hi: 5%/25%
Engine: VVTI 6 speed Manual
Turbos: J-Spec
Injectors: J-spec
Good info :thumbs:
Think I'll go with it for my UK twins when I eventually get round to getting it fitted. I know they can go to 1.4 but I'd rather play safe and see what 1.2 is like.
Try these Had these settings on hybrids
High:
Set-57 Gain-35 Set Gain-86
Low:
Set-37 Gain-30 Set Gain-55
Move the settings by 2 points up or down if these don't work out It takes a while,and good weather,to reach what you want
Good luck
High:
Low:
Good luck
Excellent thats what I like to see I will post mine this weekend when I can set it up properly.
As I said this thread is for people to be able to search and compare settings they will all be different but for people setting up there Controller it ensures they have an idea of where they can go with the settings.
If it's any use I have a record of every time I changed the settings and to what too Nearly 8 years of settings They have now changed as I run a gt35 single Keep twiddling
It would help greatly yes if you can post or email me a copy il post them for you :)
If you want more PM supraleeturbo for the settings on my old car :)
Non-vvti auto, low boost was 1 bar and high was 1.1 bar but I can't for the life of me remember the settings :(
Very good sir
